Very happy with current speakers for critical stereo listening (seas excel's) but I'd like some suggestions for a full range higher spl capable loudspeaker for the occasional 'crank it up session' or movie. I have no particular design constraints including size or $ just to say the higher the SQ the better. I have heaps of sub power but I'd like to only need them for 40Hz down.
I have thought a 15" coaxial could be cool but cant find a known design. |
#2 |
Are you asking for a high SPL design with a 15''coaxial?
http://www.users.on.net/~richard.norrish/Autograph/ IF you have the right corners...and lots of patience...and resilience... BTW, which coaxial? Cheers, M
Cheapest horn speakers: https://picasaweb.google.com/lh/phot...eat=directlink |
#3 |
The following thread on AVS was one where we did some in depth discussion on high efficiency systems awhile back. Many ended up building systems using TD12's or TD15's. Throughout the thread we ended up designing a new 6.5" high efficiency driver that is now almost ready for production. The PHL mids are the other fairly common option.
http://www.avsforum.com/avs-vb/showthread.php?t=1069020 For tweeters you can look at something like the RAAL ribbons, Fountek NeoPro5i, or go to a compression driver on a waveguide. The waveguides that Earl Geddes is doing are probably the best option currently if you're looking to go that route. We have several people who have expressed interest in mating them with our TD woofers. John |
#4 |
AE TD15S, TD10M and Beyma TPL150.
http://www.stereo.net.au/forums/showthread.php?t=12187 |
#5 | |
Hi Brett, Would you be able to post your design with those pictures up on my forum as well? www.aespeakers.com/phpbb2 John |
#6 | |
My TD15X and Unity build is two weeks away and I'll post pics there then too. |
| Power supply:Universal AC input/ Full range,High Efficiency, and High reliability | hang | Vendor's Bazaar | 12 | 24th July 2009 03:46 AM |
| Waterproof high efficiency full range? | midside | Full Range | 4 | 23rd April 2009 03:46 PM |
| Full range and/or High Efficiency possible in small cabinet? | Seraph | Full Range | 29 | 19th June 2007 01:13 AM |
| Need help with PLLXO High Pass filter for full range's! | bwbass | Multi-Way | 13 | 9th February 2005 11:15 PM |
| Best PASS amp for a high efficiency full-range speaker? | HeadSh0T | Pass Labs | 37 | 24th December 2004 04:50 PM |
| Page generated in 0.08468 seconds (76.40% PHP - 23.60% MySQL) with 10 queries |
