the two woofer/mid are 4 ohm in series
Cabinet size for the mid/woofer 11X11x8.5 inches accoustic foam will be added for resonance suppression total Here is what LEAP came up with The tweeter is a 91.5 db spl class tweeter I would have expected more higher out put |
#2 |
#2 pict
#3 |
#3
#4 |
You seem to have pointlessly low treble impedance. Tweeter levels depend on matcing the bass/mid, not raw sensitivity. |
#5 |
Leap crossover design info
woofer mid in series 2nd order design L 1.2 C 8Uf Zobel 20Uf 50 Ohms tweeter 10 UF .2 L anteunation series R 7.5 series to Tweeter 50 parallel Question of adding another tweeter and using potentiometer to balance brightness between the two tweeter to increase impedance of the circuit? And any other ideas or thoughts are highly welcomed |
#6 |
two tweeters is not ususally a good idea, google 'comb filtering';
That FR looks good, no need for much BSC
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#7 |
Reduce the value of the series resistor, or maybe even remove both resistors in the tweeter circuit. Tweeter output will increase, but you may have to retune the crossover.
| Experience with this DIY DAC ? | ah-luo-ko-ko | Digital Line Level | 3998 | 20th May 2012 01:28 PM |
| my t-amp experience | Eggzy | Chip Amps | 35 | 17th December 2005 06:29 PM |
| DAC experience with the following | amperex | Digital Source | 4 | 28th September 2005 12:55 PM |
| anyone experience with this amp? | Hanzwillem | Solid State | 1 | 31st October 2003 05:46 PM |
| Page generated in 0.08396 seconds (75.52% PHP - 24.48% MySQL) with 11 queries |
