My latest: Open baffle mid, Lambda TD12H, B&C 6md38, Peerless HDS
Old 3rd March 2009, 12:29 PM   #1
dlneubec is offline dlneubec  United States
Default My latest: Open baffle mid, Lambda TD12H, B&C 6md38, Peerless HDS
I call these the BaSSlines. They were inspired by a pair of speakers I heard last year designed by Jeff Bagby and Jim Salk of Salk Sound (hence the BaSS in the name). They are a 3way using a 12" Lambda TD12H in a 52 liter, slot ported cabinet (F3 around 35hz) with an open baffle B&C 6md38 6.5" midrange and a Peerless HDS tweeter mounted in a shallow waveguide. The sensitivity is probably around 92db.
I hope to have the finish wrapped up in the next week or two and then will make final crossover tweaks, if any, and publish the completed design. I used a small spare room we have upstairs to do the finishing in, since it is easier than doing out in the garage this time of year. I etched the logo on the Lexan with by hand with a dremel using vinyl stencils (that John over at AE speakers did for me, thanks John!) as a guideline.
There is a more complete build thread here:The BaSSlines
Thanks for looking.
Dan N.
Old 3rd March 2009, 01:43 PM   #2
trusound is offline trusound  United States
trusound's Avatar
Send a message via AIM to trusound
wow... great looking speakers... great color,theme and good use of mixed mediums...
how do they sound
Old 3rd March 2009, 01:52 PM   #3
Thanks.
I'm thrilled with how they sound. IMHO, they are my best work so far and are up there with the best I recall hearing at DIY events over the last few years. Wide and deep soundstage, very clean and dynamic and forgiving of all kinds of material.
Dan N.
Old 3rd March 2009, 04:19 PM   #4
nullspace is offline nullspace  United States
nullspace's Avatar
Super job Dan. They look really nice.
John
Old 3rd March 2009, 08:57 PM   #5
gainphile is offline gainphile  Australia
gainphile's Avatar
Very nice looking pair of speakers
Why skip the OB bass? Those could easily be H-frames.
http://gainphile.blogspot.com
Old 3rd March 2009, 11:40 PM   #6
penderaudio is offline penderaudio  United States
Those are great! I love the look and the and the different materials used. Very creative!
I have been thinking of something similar with a Hawthorne 10" coax and a AE'TD10s in a ported box for the lows. Looking for an alternative to Dipole bass, some living spaces are just too picky on placement for a full Dipole system. I figure the Lamda series would work well with the speed of the 10" Hawthorn drivers 95db spl.
Are yo happy with the AE Drivers so far?
-Jamie-
Old 4th March 2009, 01:45 AM   #7
Thanks.
This speaker was inspired by a prototype designed by Jeff Bagby and Jim Salk. When I heard it at the InDIYana DIY event last April, I just knocked me out. I thought it was the best speaker I have heard and it inspired me to see if I could duplicate it's sound. It used the same Lambda TD12H woofer, but a PHL mid and Morel dome tweeter. Anyway, dipole bass was never an option I even considered for this design. I'm not sure it would be right for my listening room anyway.
Dan N.
Old 4th March 2009, 01:52 AM   #8
-Jamie-
Thanks. I'm very pleased in how it turned out, both aesthetically and from a sound quality standpoint. I had used the combination of exotic wood veneer, metal and acrylic in a previous design and I wanted to take it a step further. I also wanted to reduce the apparent mass of the speaker in the room and making the top section predominantly transparent really does this quite successfully. I've always liked mixed hardwoods in furniture.
The TD12H I'm using in this design is the best woofer I've used and IMHO, the best I've heard. It is literally flat out to about 4khz and is very clean, extremely dynamic and works in a pretty small box, as you can see.
Dan N.
Old 4th March 2009, 05:23 AM   #9
SamL is offline SamL  New Zealand
Very nice looking speaking. Is there any reason why the bass driver is so near to the floor and away from the mid? Won't you get bass boom from such arrangement?
Old 4th March 2009, 06:56 AM   #10
thadman is offline thadman  United States
It's placement was chosen to avoid interference from floor bounce in the lower midrange.
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them."
My latest: Open baffle mid, Lambda TD12H, B&C 6md38, Peerless HDSHide this!Advertise here!
Does open baffle suffer from baffle step? 454Casull Multi-Way 15 19th May 2012 03:12 PM
Murphy baffle radios [ open baffle ] keithpeter Full Range 10 11th September 2007 07:59 PM
what effect does baffle have on open-baffle system? kappa546 Multi-Way 6 24th January 2006 10:21 PM
Australians- what solid timbers for baffle? (open baffle loudspeaker) tktran Multi-Way 13 29th November 2004 11:09 PM
Latest incarnation of my open baffle/dipole speaker tom1356 Multi-Way 24 22nd May 2004 04:19 PM
