My dad didn't like the looks so here's a new design which he does like.
old thread 3 way for my dad tweeter 3/4" Eton 25SD1 mid 7" 7-360/37 HEX 4Ohm bass Audes 75W104-4 mid 8 liters bass 120 liters port at 30Hz |
#2 |
This is the crossover and frequencycurve.
I thried to keep it simple and effective. |
#3 |
And at last I made a printscreen of the off axis frequency response.
Thisone is important for me because possibly the speakers will be in a sideroom. |
#4 |
Oke, I made a new start, my dad likes the new design and so do I.
1. Sonus Faber Stradivari - style 2. Closed box instead of BR because of uncertain boxvolume due to making the box in about 60 layers of 18mm mdf and faster reaction. 30l for mid 40 l for basswoofer, more volume gives less output |
#5 |
At last, someone whole concentrates on aesthetics first!
But then makes the sound good as well. |
#6 |
XO
#7 |
of axis is nice now i think
and rjb aesthetics is important for an architect do you like the design? is it sonus faber,? i tried to make it also a little different and doable. it will be about 60 layers of mdf and the frontplate and backsideelement will nicely fit in |
#8 |
Nice. Looks like it only needs one structural curved shape to fabricate the box. What is the skin material? If it's a kerf-type board you might look to see if your minimum radius exceeds the maximum bend of the material.
#9 |
dzzmiller
you are right, the mainvolume is built from only one structural curved shape. outside is veneer, an radius will do i think |
| Service Manual Request: Marantz CD75 MkII or CD65 MkII | jeff mai | Digital Source | 9 | 23rd April 2009 04:48 PM |
| Adcom GFA-555 MKII turns on, blows fuse, speaker hums down | £§«û‰ | Solid State | 8 | 21st June 2008 10:52 PM |
| RB 971 MKII with tubes | egnolegno | Solid State | 3 | 19th March 2004 08:34 AM |
| Vaa100es Mkii (please Help!!!) | Apogee | Tubes / Valves | 8 | 3rd May 2003 02:08 AM |
| CAT SL-1 Sig MkII | puppyslugg | Tubes / Valves | 7 | 24th November 2002 12:20 AM |
| Page generated in 0.08094 seconds (83.63% PHP - 16.37% MySQL) with 11 queries |
