Cheers.
Which would be the better tweeter for this 4 way diy design: Woofer 15" [97dB]: Beyma 15B100/R (0-200Hz) Mid-Bass 8" [95dB]: Beyma 8M60N (200-1000Hz) Mid [91+91dB]: 2 x Beyma MC115 (1000-4000Hz) Tweeter: Beyma T2030 (horn, 95dB) or Monitor Audio GR60's tweeter (Seas Excel variation, 91dB) Image of front of the speaker: |
#2 |
Vifa D26NC55 1" Textile Dome Tweeter found on Ebay at a good price
Vifa DQ25SC16-04 1" titanium Dome Tweeter Vifa XT25BG60-04 Vifa Ring Dome Tweeter - Double Magnet - 4 ohm Seas 27TBFCG Dayton RS28A4 SB Acoustics SB25STC These were chosen from http://www.zaphaudio.com/tweetermishmash/ you will find many people will referr to his sight or you could get some polk audio tweeters at a good price to www.mavin..com |
#3 |
Why not make the Beyma theme complete and use a TPL150?
#4 | |
Yes, my thought too, and loose the mid domes too btw, how do you get that 15B100/R to play bass...I have looked at it several times, but it falls like a brick above 50hz, very low Qts Might want to look at SM115N But you must be careful not to get too much midbass |
#5 |
Thanks for all the answers.
Regarding the Beyma 15B100R, from WinISDN software I get this excellent response: 28Hz (-6dB = 91dB) 31Hz (-3dB = 94dB) 37Hz (0dB = 97dB) (Volume: 253L - Tune Fre. 32Hz - VAS 400L - Fs 25Hz) Replacing the mid-drivers is not an option because I like the sonic result. Using a TPL150 would provide more accuracy but less fun. These mid drivers follow the design on the Proac D100 with double ATC mid drivers. The sound gets much more 3D, natural, and warm. Maybe less audiophile but definitely more musical and pleasant to the ears. The golden tweeter of the Monitor Audio G60 is truly amazing (dispersion, resolution, extension). The only problem is that it is low sensivity (91dB) and will force me to attenuate the other drivers. Then again, Proac D100 does this to. |
#6 |
I saw a test K&T of dome midranges the beyma dome did distort ad lower frequencies.
The morel EM1308 would be a better choice. And a tip for good high spl dome tweeter with very flat response 5kHz and up, and not expensive at all. Monacor dt-25n 95dB 1W/mtr dt-25n
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet |
#7 | |
#8 | |
A dt25n cost 24 euro When you can rit of exclusive taste you can save huge amounts of money. And spend more on musik
#9 |
Helmuth, it is so - Beyma MC115 and 8M60N show some distortion at low frequencies, but I will cross them a little higher (200Hz and 1000Hz, 12dB/oct) to avoid it.
Now, concerning the Monacor dt-25n, I'm sure it is great but from its picture I see the horn is too pronounced (too closed). Data is not available but I'm sure this will make it highly directive (low dispersion). Low-dispersion tweeters like this are only adequate for one listener that is at the same distance from both tweeters. Also, the listening angle to the tweeter should be low (zero if possible), otherwise that flat response will be gone. These speakers I'm building are meant for family auditions. |
#10 | |
It is 1 cm deep this means it only will work as a horn from about 9kHz For this price it could be worth a try. Regards, Helmuth
| SEAS 5-tv hf tweeter | damianl | Multi-Way | 23 | 15th July 2009 12:09 PM |
| Tweeter 95dB eff and from 1500Hz x-over anyone? | Cordraconis | Multi-Way | 5 | 27th June 2008 03:33 PM |
| Any SE project for 91db speaker? | laiben | Tubes / Valves | 24 | 31st October 2007 01:55 AM |
| Alternatives to beyma T-2030 tweeter? | Sony | Multi-Way | 0 | 29th November 2004 05:35 PM |
| Beyma CP25 Horn Tweeter | Elso Kwak | Multi-Way | 4 | 1st May 2004 07:21 PM |
| Page generated in 0.10982 seconds (81.43% PHP - 18.57% MySQL) with 11 queries |
