Old 24th February 2009, 11:12 PM   #1
Default Passive Notch Filter for Eminence Alpha 15As
I am using a pair of these in an OB design and passively crossing around 900 Hz (2nd order BW) to one of Earls 15-inch WGs with compression driver.
I still hear a little coloration in the Alphas. Can anyone point me to a site or calculator as I want to try a passive notch to passively filter a pair of these (4 ohms) around 2 Khz as I think that is where the problem is.
http://www.usspeaker.com/ALPHA15-1.htm
Or should I just go 4th order passive to try to filter the 2 Khz peak?
Old 24th February 2009, 11:42 PM   #2
infinia is offline infinia  United States
infinia's Avatar
Not sure what you have for BSC and what else you are using for open baffle correction (s/b active?) circuit wise, but painting in broad strokes...
If it were me and I wasn't going active or using a different woofer I'd use a biggish BSC inductor with notch for open baflle and another for the woofer breakup. Note the breakup is highly directional and probably gone at 45-60 deg off axis.
You could look at using an eliptical 3rd order LPF depending on the preceding inductor/filter used for the other corrections.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 25th February 2009, 05:28 PM   #3
900hz is too high for these woofers.
at this frequency FR needs to be dropped real hard
I'd do 4th+ order and notch.
it would get quite expensive with passive components.
calculators won't work. the can give you general idea what values to look for. but for precise crossover drivers must be measured.
Old 27th February 2009, 04:22 AM   #4
Default here is a website
http://www.diyaudioandvideo.com/Calc...ParallelNotch/
Passive Notch Filter For Thd Measurement fotios Solid State 8 7th July 2008 07:29 AM
Eminence Alpha 10 chris661 Subwoofers 16 1st March 2008 09:43 AM
FS: Eminence Alpha 15A x 4 jeff mai Swap Meet 5 15th April 2007 04:40 AM
passive notch filter, how much power do they take? Puggie Multi-Way 4 3rd February 2006 01:19 AM
WTB: USED eminence alpha 10 kan3 Swap Meet 0 31st December 2003 09:12 PM
Page generated in 0.06494 seconds (77.86% PHP - 22.14% MySQL) with 10 queries
