B&W 804 Nautilus, crossover schematic filter
Old 23rd February 2009, 09:29 PM   #1
ancestrale59 is offline ancestrale59  Italy
Default B&W 804 Nautilus, crossover schematic filter
Can anyone of you guys point me to (link, email, whatever) schematics crossover filter of B&W Nautilus 804 ?
Thanx in advance
Giuseppe
Old 27th February 2009, 08:52 AM   #2
Agent327 is offline Agent327  Netherlands
There has been a 'Boxenklinik' article about the nautilus 804 in "Hobby Hifi", where they designed a new filter for it.
Interesting loudspeaker magazine.
Sorry, no scanner here.
I think you can buy back issues.
http://www.hobbyhifi.de/Archiv/07/04_07/04_07.html
I cannot remember if the original schematic was in the article.
Old 27th February 2009, 01:21 PM   #3
Many thanks, the information was very useful, the journal contains the schema.
Old 28th February 2009, 11:36 AM   #4
I think the filter shown in the article is the one designed by HH, not the original.
Are you going to try the new one?
Old 29th December 2012, 06:35 PM   #5
Uunderhill is offline Uunderhill  Canada
Has anyone tried modding N804 crossovers ?
I've looked for a copy of Hobby HiFi April 2007 - but no luck.
Any suggestions ?
Old 29th December 2012, 09:59 PM   #6
The Nautilus 804 has 3 crossover boards - one for the tweeter, FST mid range unit and one for the 2 LF drivers.
All 3 crossover boards can be accessed by removing the LF drivers.
So the FST mid range unit does not need to be removed to get access to the mid or HF crossovers
The HF crossover board has
L1 - small air core inductor
C1 - 4.7 uF length = 1 3/8"
C2 10 uF length = 1 3/4"
R1 = 2R2 11 watts - with Bennic inked as the make
My experience with commercial wire wound resistors - used for audio - is that they sound harsh.
A harsh sounding resistor, in series with a Nautilus metal dome tweeter, is less than ideal.
So replacing the 2R2 resistor with a Mills or Mundorf would probably improve the sonics.
Replacing the 4u7 cap with a Mundorf Supreme or Silver Oil would certainly make an improvement - however, I'll have to check if one will fit.
Another option maybe replacing it with a Mundorf EVO gold silver oil cap.
But have yet to hear the new EVO gold silver oil caps
Here is a photo of the Nautilus 804 HF board.
Old 29th December 2012, 10:45 PM   #7
Kindhornman is offline Kindhornman  United States
Kindhornman's Avatar
ancestrale,
Unless you have the exact same drivers which I would doubt why would you want to clone that crossover? Just from the simple description of it it doesn't sound like anything special, actually sounds rather like a crude 1st order network. As for all the hype about oil filled whatever save yourself a lot of money and buy some good polypropylene capacitors and quality large gauge inductors.
Old 29th December 2012, 11:41 PM   #8
Thanks for your response.
Moving from the original B&W Nautilus series from the 1990's, to the Diamond series,
B&W improved the crossover components to upper end Mundorf's in key locations.
They used regular MKP's in non critical locations.
With my B&W 603 s2's, I replaced the caps in series with the tweeter
with an AuriCap and a Mundorf Supreme.
The series resistor was replaced with a Mundorf metal oxide.
The AuriCap and Mundorf Supreme seem to complement each other quite well.
I made these changes one at a time, and each change, for whatever reason, reduced harshness.
As you've pointed out, an original intent, of opening up my N804's,
was to see if the inductors connected to the LF drivers, could be replaced
with ones that have a lower resistance.
However, looking at the LF board, I can't see any markings for the inductor values.
So they would have to be pulled out and their values measured.
I'd use a frequency sweep of an LCR circuit and find the resonance.
If they were to be replaced, almost certainly ferrous cores would be needed.
Here is a photo of the N804 LF crossover board.
Old 30th December 2012, 12:02 AM   #9
The diameter of the magnet wire, on one of the LF inductors, consistently measures at 0.044"
This converts to 17 awg - but I would have expected an even gauge like 14, 16 or 18 awg.
However, 0.044" is the diameter that consistently comes up.
Old 30th December 2012, 12:54 AM   #10
Uunderhill,
This is my opinion and I am sure there are as many of those and people who will answer this thread. If you want to improve the sound of your B&W speakers I would look at a few things. As you have seen B&W like most manufacturers look where they can cut corners. One is in the quality of the crossover components. I would think about air core inductors for an improvement and not an iron core inductor. This is a cost saving move, a larger wire diameter and no iron core will take the core saturation out of the picture that you now most likely have. Yes you would have to take the inductor out to get the value. If you really want to make a significant difference you would be much better off trying to add a Zobel network to the devices to flatten the impedance rise in the devices. The next move up as far as I am concerned in a passive crossover would be to go to 4th order crossover designs but that would be a major change and unless you can measure the speaker parameters that would be a shot in the dark. I can't help you go past this point as I don't have any specific information about the devices.
B&W 804 Nautilus, crossover schematic filterHide this!Advertise here!
Do you need a crossover/filter for a sub? TheLaw117 Multi-Way 7 10th March 2011 12:18 AM
Matrix 804 problem jamesjia1234 Multi-Way 2 6th August 2009 09:32 PM
B&W Matrix 804 tweeter replacement.. Richard Moon Multi-Way 7 18th September 2008 07:32 PM
PE #300-804 plate amp mods finally! crippledchicken Subwoofers 0 10th February 2005 09:23 PM
Crossover or filter Optical Chip Amps 3 16th December 2003 02:52 AM
Copyright ©1999-2017 diyAudio
