aligning drivers
aligning drivers
Old 23rd February 2009, 08:44 PM   #11
mrkramer is offline mrkramer  United States
Is a delay on an active system equal to physical alignment of drivers? Is there is more to it than that?
Nobody mentioned waveguides. I could see shallow guides as an option as well. Too much of a can of worms?
trusound: I like your "RGB"s. Interesting look. Nice to see some non box shapes.
MrKramer
Old 23rd February 2009, 08:48 PM   #12
trusound is offline trusound  United States
trusound's Avatar
Send a message via AIM to trusound
Originally posted by The golden mean
Sorry, while a sphere as the external image of an enclosure could be a good thing when it comes to spread diffaction with regards to frequency, a sphere or a tube as the internal shape of an enclosure isnīt the best shape because standing waves will be gathered at certain frequences. Having visited conserts in "the Globe" in Stockholm and the lectue-theatre that has a dome as aprominent part to it.
About the time alignment the problem is that time delays because of a crossover e.g. is not cured by a "step function" as it is a continuous rather than a descrete function.
not when you build the inside like I built my last pair
Randy Kunin
www.randall-k.com
Old 23rd February 2009, 08:51 PM   #13
trusound's Avatar
delay is delay... either electrical or mechanical.. though I'm a huge proponet of get it right mechanically then touch it up electronically..
and thanks.. they are called the 'Narrows" not the "RGB's".. that's how I draw
MrKramer
Randy Kunin
www.randall-k.com
Old 23rd February 2009, 09:29 PM   #14
abefroeman is offline abefroeman  United States
Delay in active crossovers should be the same as physical delay, except that in an active system it is done without any calculations because some digital crossovers can detect the proper delay with a microphone.
Old 23rd February 2009, 09:32 PM   #15
454Casull is offline 454Casull  Canada
I'd just use the simple formulas if I were to build my own active crossover. The Behringer Dxxxxxx does it though, I think.
Old 23rd February 2009, 09:44 PM   #16
The golden mean is offline The golden mean  Sweden
There is still a high degree of symmetry which in my opinion should be avoided.
About stuffing; there might be a problem with reflection from the stuffing material itself and this is probably greater if an enclousure is densly stuffed.
I like a little more chaos in the interior structure like in the Kharma loudspeakers.
http://www.kharma.com/_images/review...und/page_2.jpg
Without wonderment,no life.
Old 24th February 2009, 01:57 AM   #17
dlr is offline dlr  United States
Active delay is not the same as physical alignment anywhere except at the design point. When drivers are not physically aligned, the off-axis will have an even larger variation due to the change in excess-phase from changing distances that is complicated by the now-not-optimal electrical time delays at all off-axis points.
If the drivers are physically aligned, the off-axis variation will likely be lessened vs. non-aligned but time-delayed.
One can debate the relative merits, benefits and problems of each, but not the physics of it.
Dave
Old 24th February 2009, 03:59 PM   #18
In the simplistic world of many hi-fi journalist phase shifts can be cured by placing the drivers at different distances from the listener. I read a German hi-fi mag where the drivers could be set to a millimeter resolution and indeed was placed this way as well.
In the real world phase errors canīt be solved so very easely.
Many years ago I had a pair of loudspeakers each being composed of two boxes. One for the woofer, one for the midrange and a moveable "rider" on top of the triangular mid boxes and the rider hold the tweeter. I spent a lot of time trying to determine how the drivers should be aligned in relation to each other. There were significant differences to the sound when moving the drivers back and forth. But the problem was that it was very hard to determine the absolute best position. As said I used many hours in listening and in order to find the optimal positions. But it was a never ending story.
My new speakers have a similar approach in divideing the drivers into separate boxes. Being a four-way system itīs now easy for me to know that I should make other priorities. Mixing a lot of materials for the enclosures and thinking of asymmetry for the area where the wave length is short enough to be effected by some "tricks" is now in focus. Rigidity and internal dampening as well as irregular shapes where it counts is now the order. Or order should be exchanged for chaos to some extent.
Credit to mrkramer for trying something different. You may learn a lot from this!
aligning driversHide this!Advertise here!
Aligning Optical lens in a NAD C-540 CDP arupg Digital Source 27 10th February 2012 04:26 AM
Aligning Rega Elys Cartridge edwilks Analogue Source 6 21st May 2007 08:30 PM
time-aligning a super tweeter cporada Multi-Way 26 8th September 2006 12:03 AM
Time aligning subs, mains, etc. tiroth Multi-Way 16 24th December 2004 04:28 AM
Time Aligning Questions mrfeedback Multi-Way 1 6th May 2002 01:49 PM
