Hey all, I found a 2-way floorstanding monitor design that I like and I would like to build shorter cabinets and use stands. Baffle width will stay the same but the speaker will end up shorter. Will this effect my BSC?
#2 |
Check it with one of the baffle modelling tools. It will do if you mount the bass mid very close to the bottom, further is harder to define. |
#3 |
Define 'Shorter'?
Do you mean shorter with less volume or shorter with equal volume? I think baffle step is mostly related to baffle (front panel) width, so I suspect you would be OK relative to baffle step. But if you shrink the overal volume of the cabinet, the cabinet tuning and bass response completely change. I think that is why SReten suggested you use a modeling program, so you can visualize the effects of the changes you are going to make. Again, I think if all other dimensions remain unchanged, and you make the cabinet shorter, you are losing bass because you are losing overall volume. A modeling program should show you the changes to the frequency response clearly. Just an opinion. Steve/bluewizard |
#4 |
Internal volume will stay the same.
basically i am removing the area of the floorstanding plan that is dedicated for filling with sand, and replacing it with a speaker stand. |
#5 | |
/Peter |
#6 |
Peter,
I have no problem bowing to superior knowledge, but could you explain how cabinet height effects Baffle Step. I always thought it was related specifically to baffle width in the area of the woofer. In reality he is not going to change the cabinets internal working volume, so why should the parameters or response of the cabinet change? I confess I'm no expert, but an expansion of your response would be helpful. Steve/bluewizard |
#7 |
Baffle height will change the radiation pattern in the vertical direction. Think about it, you could flip the speaker and now your height is the new width!
#8 |
Isn't it simply because the driver radiates in a sphere (or half sphere, depending on frequency). Therefore, the height also makes a difference to that forward radiation.
However, as most baffles are narrower than they are wide, the biggest effect is caused by differences in width, because this has the greatest effect on total baffle area per mm of change in dimension (width vs. height). I think, anyway... Stuey |
#9 |
where can I find a calculator for BSC?
#10 |
Doesn't the Allison Effect cause frequency response dips/peaks relative to the speaker height (as well as wall distance)? I would think that this should be taken into account as well. I guess you could also just measure the frequency response with varying cabinet heights to see if you need to change your BSC!
SG |
| Golden Ratio Height | edjosh23 | Full Range | 13 | 3rd February 2009 09:52 PM |
| BIB and ceiling height | Mr.Mekulic | Full Range | 7 | 21st November 2007 07:58 PM |
| Can Ariel's height be reduced? | zdr | Multi-Way | 1 | 18th May 2007 09:40 AM |
| Two way system, Mid-woofer height? | Audist | Multi-Way | 1 | 9th December 2005 08:23 AM |
| Page generated in 0.10097 seconds (78.76% PHP - 21.24% MySQL) with 10 queries |
