Should BSC change when cabinet height changes? - Page 2 - diyAudio
Old 24th February 2009, 08:22 PM   #11
infinia is offline infinia  United States
infinia's Avatar
Originally posted by abefroeman
where can I find a calculator for BSC?
http://www.tolvan.com/edge/
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 24th February 2009, 08:55 PM   #12
very cool, thanks.
Old 24th February 2009, 09:10 PM   #13
infinia's Avatar
RE edge.exe
looking at the first compensation circuit
set R1= speaker impedance at f1- f2 (typically around Re)
L = BSC inductor to give full BSC (6dB)
R2 at higher frequencies provides 6dB cut relative to frequencies before f1 (20logR2/(R1//R2)) i.e. it's an 1/2 voltage divider.
R2 is typically omitted in internal LPF speaker crossovers/mid driver box response and can be seen again as relating to padding of the HPF (tweeter) section.
Old 25th February 2009, 10:53 AM   #14
Pan is offline Pan  Sweden
Yes the matter was nicely explained after my short (sorry :-) post.
/Peter
Golden Ratio Height edjosh23 Full Range 13 3rd February 2009 09:52 PM
BIB and ceiling height Mr.Mekulic Full Range 7 21st November 2007 07:58 PM
Can Ariel's height be reduced? zdr Multi-Way 1 18th May 2007 09:40 AM
Two way system, Mid-woofer height? Audist Multi-Way 1 9th December 2005 08:23 AM
Copyright 1999-2017 diyAudio
