Old 23rd February 2009, 12:19 PM   #1
56oval is offline 56oval  Australia
Default Fitting drivers in cylinders pros & cons
Hi DIY
Is there any hidden problems fitting drivers in cylinders .
This is just a rough sketchup I was thing of using a clear acrylic
frame to support the tubes .
The cylinder cabs will be made of steel or alloy which I know how to work with .
Heres the original cab I was going to build
Cheers
Old 23rd February 2009, 12:32 PM   #2
Khron is offline Khron  Romania
Send a message via AIM to Khron Send a message via MSN to Khron Send a message via Yahoo to Khron
You might find a "pearl of wisdom" right after the first graph, on this page
Old 23rd February 2009, 01:09 PM   #3
Hi Khron
I have a copy of Olson's AES paper and I can't find what size driver he used and I think it wasn't that large and the cylinder
had an end plate 24" just under 610mm wide with a small driver in the middle would the test out come be the same if the driver's diameter is as close to the edge as possible .
Hmmm might have to make a clear acrylic front baffle .
Thanks for the reply
Old 23rd February 2009, 09:16 PM   #4
Sure, although when the driver is large compared to the baffle it becomes directional and lessens the diffraction problem.
Compare and contrast Siegfried Linwkitz' measurements of a 25mm tweeter naked (1.5" baflfe) and on a 3" circular baffle with the Pluto (1.6" tweeter, ~2" baffle). 6 and 12'" measurements are also provided for the 1" dome.
http://www.linkwitzlab.com/diffraction.htm
http://www.linkwitzlab.com/Pluto/specs.htm
The Pluto is getting directional before it's an issue.
I suppose the ribbon tweeter will force a high cross-over point, although a small enough mid-range would keep that from being a problem.
Old 23rd February 2009, 10:23 PM   #5
pos is offline pos  France
pos's Avatar
56oval, check this you:
http://www.audioheritage.org/vbullet...ad.php?t=12126
construction:
http://www.audioheritage.org/vbullet...2126&page=3#35
Old 24th February 2009, 01:30 AM   #6
pos's Avatar
typo: "56oval, check this out"
Pro vs hifi drivers - pros and cons? Defo Multi-Way 988 8th January 2011 07:14 PM
pros/cons of a 845 VS 211 jarthel Tubes / Valves 2 18th June 2007 01:57 PM
TL vs MLTL, pros and cons Tomac Multi-Way 5 29th December 2004 01:55 PM
Filterless DAC - pros and cons? mr_push_pull Digital Source 1 11th August 2004 03:56 PM
Pros and Cons of this technique? G Tubes / Valves 35 23rd October 2003 06:37 PM
Page generated in 0.09670 seconds (77.95% PHP - 22.05% MySQL) with 10 queries
