2.5 way with DE250 / RCFH100
Old 22nd February 2009, 02:39 AM   #1
AudioGeek is offline AudioGeek  United States
Default 2.5 way with DE250 / RCFH100
after thinking about the Radian 5208c i came across the DE250 driver and horn.
I would like to keep the high sensitivity 96db or greater. But maybe throw on a couple of 10" or 12" drivers in a 2.5 way configuration. Probably ported.
Problem is that a LF driver that goes nice and low usually is quite expensive and i would need 4 total. Also, most have quite a bit of ripple 2Khz and up.
so what drivers could i use for the LF?
thanks!
It is not you... you are it.
Old 22nd February 2009, 02:57 AM   #2
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Default Re: 2.5 way with DE250 / RCFH100
thanks!
I have been close to building a similar design...a 2.5way with 12" and 18" and Azura horns
I believe theres some risk of phase issues using diffferent woofer fore a 2.5way
It may work ok though, Im just saying it might not be that simple
And tweeter horns could be tricky things too
Below is my present goal fore a high sensitivity design
Quite affordable really, due to the cheap BETA-8...but the Beyma AMT ribbon TPL150H does cost a significant bit
Unfortunately the needed subs might cost equally as much, or more
Be aware that crossovers are not so easily done, though I expect the ribbons might make things just a bit easier
Active systems seems to gain in popularity and doesnt need to cost a fortune
sometimes we know very little, and sometimes we know too much
Old 22nd February 2009, 03:07 AM   #3
or....
get a really high sensitivity LF driver and use a BSC and loose 6db.
then only need 2 LF drivers total.
then just a simple 2 way.
any 10 or 12" drivers that would work with the DE250 and go low? 40-50Hz in a ported cab?
Old 22nd February 2009, 07:01 PM   #4
tomcat9 is offline tomcat9  United States
I am planning a high sensitivity design also. For the woofer, I plan to use the B&C 15NW76. This is a 15 in woofer that is 100 db spl. In my design, I am not trying to get the very lowest sub-bass, but more concerned that bass, mid-bass, and low midrange sounds the best. In my design, I plan for this woofer to play up to about 500 hz.
If you notice, each B&C woofer has either a radial, or an exponential cone shape. They recommend the radial shape for the lowest bass and sub-woofer usage. The exponential designs are recommended for woofer and mid-woofer.
Old 22nd February 2009, 09:48 PM   #5
ttan98 is offline ttan98  Australia
thanks!
Good choice I am currently using the De250 and RCF100 horn combo, sound rather good, you don't even have to equalise the combo.
The woofer I am using is an old alnico I bought from E bay and sounds good as well. I like to suggest you may want to look at 10" woofer from Abrown/Tone Tubby. Its is about $100 each comparable to Eminence. If I design a 2.5 way speaker I will use 8"/10" ceramic as mid and 10" super boy as bass.
refer to this site for details:http://www.tonetubby.com/ts.html
2.5 way with DE250 / RCFH100Hide this!Advertise here!
18sound NSD1095N v's B&C DE250 D OB G Multi-Way 83 5th December 2011 01:32 PM
B&C DE250 comparison on XT1086 kstrain Multi-Way 42 3rd February 2009 03:11 PM
Polarity of B&C DE250? Horizons Multi-Way 0 31st October 2008 05:57 PM
B & C DE250 assembly Ed LaFontaine Multi-Way 3 18th August 2008 03:56 PM
Copyright ©1999-2017 diyAudio
