I'm in the process of building two floor standing speakers. Just some stuff I had laying around.. anything terribly wrong with what I'm doing? Box is built out of 1/2" MDF with a good amount of bracing and separate enclosure for the mid/highs.
1x Dayton Classic 6.5" woofer (side firing) 4x Pioneer NSB 4" 69 cent speakers 2x Onkyo 3/8" tweeters Crossovers are 12dB/octave active Low-pass @ 200Hz Band-pass 200Hz-6KHz High-pass 6KHz Overall outer dimensions (in): 5.25 (front)x7.5(side)x49 Volume for 6.5" woofer cabinet: ~0.5cu ft - 0.55cu ft, considering adding a 2"x9" port Pioneers and tweeters are rear mounted. 3/8" radius on the holes. 3/8" radius on all cabinet corners. |
| Expectations of new tube specs | d1camero | Tubes / Valves | 5 | 2nd May 2008 03:53 PM |
| Expectations from an inexpensive 3-way | peter_m | Multi-Way | 4 | 27th May 2007 09:14 AM |
| Acceptable criticism (from Feedback artifacts) | millwood | Everything Else | 13 | 24th February 2004 03:01 AM |
| Isobaric 8" expectations?! | Rarkov | Multi-Way | 18 | 12th September 2002 02:41 PM |
| Page generated in 0.05692 seconds (68.27% PHP - 31.73% MySQL) with 10 queries |
