LF driver on side versus front
Old 21st February 2009, 07:59 PM   #1
AudioGeek is offline AudioGeek  United States
Default LF driver on side versus front
what are the adv/disadv of having the bass driver on the side of the cabinet vs the front?
how do i work out the sensitivity required for a driver on the side if my HF and mids are at 96db?
does the diver on the side do away with the BSC requirement?
I am looking for a driver to go well with a Radian 8" coaxial. Probably either use a sealed cabinet for the Radian... or even just do an OB.. or vented... i guess i do not know yet what would work better.
Nice taught bass, good impulse response etc and low THD are all qualities i am looking for. size not really that important being on side.
Thanks!
It is not you... you are it.
Old 21st February 2009, 10:29 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Default Re: LF driver on side versus front
It depends on the cut off frequency and room placement among other things.
[i]how do i work out the sensitivity required for a driver on the side if my HF and mids are at 96db?[/B]
Consider buying a plate amp for the woofer.
[i]does the diver on the side do away with the BSC requirement?[/B]
It does if you have a powered woofer.
[i]I am looking for a driver to go well with a Radian 8" coaxial. Probably either use a sealed cabinet for the Radian... or even just do an OB.. or vented... i guess i do not know yet what would work better.[/B]
I like the OB idea if you can stand a baffle size that will give you 100Hz. Either that or maybe two boxes in one to keep the drivers separate and high pass the Radian at 100 Hz. That's the sort of thing I have done.
[i]Nice taught bass, good impulse response etc and low THD are all qualities i am looking for. size not really that important being on side.[/B]
That's what we are all looking for. How much do you to spend?
planet10 needs your help:
Let's help Ruth and Dave
Old 21st February 2009, 11:16 PM   #3
cost? well considering the radian is around 300 each.. i guess i am open to suggestions.
would it just be easier to put all the drivers on the front?
maybe then i could just use a couple of 12's or 10's on the front with the radian.
go with a 2.5 way or something.
thanks!
Old 21st February 2009, 11:20 PM   #4
Speakerholic
Cal Weldon's Avatar
That works too.
Old 21st February 2009, 11:58 PM   #5
454Casull is offline 454Casull  Canada
If a side-firing driver plays above its baffle step, won't the polar response be assymmetrical across the front vertical axis?
Old 22nd February 2009, 12:30 AM   #6
Speakerholic
Cal Weldon's Avatar
You would have to keep the XO point low.
EDIT: or make them mirror image so you can have them firing in or out depending on the room.
LF driver on side versus frontHide this!Advertise here!
sigle drivers(front side) crick Swap Meet 0 31st May 2008 05:10 PM
XXLS low bass - Facing Front, Side, Down or Back DEQ+TheEnd Multi-Way 1 11th November 2006 12:26 PM
Low side driver as a High side fr0st Parts 0 8th May 2004 03:14 PM
mtm versus tm driver recommendations on project with $500 driver and xo part limit gsattler Multi-Way 4 20th May 2002 06:54 PM
Copyright ©1999-2017 diyAudio
