diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Sealed enclosure questions.. (http://www.diyaudio.com/forums/multi-way/139002-sealed-enclosure-questions.html)
Defo 20th February 2009 08:22 PM
Hey,
I'm about to build a sealed box for my two Klipsch RF-82 woofers, and I wondered..
Should each woofer be in a separated chamber by themselves, or both in the same chamber? Whats more common?
- Defo
gedlee 20th February 2009 09:22 PM
If they see the same signal then the same chamber is fine - better in fact.
badman 20th February 2009 10:51 PM
Better how? I've seen analysis that showed no significant benefit to separating chambers, but what's the upside?
Pan 20th February 2009 11:23 PM
If the small signal parameters are identical you can safely use the same volume (especially if you mount the woofers symetrical) If not it's better to use separate volumes.
I assume you are going to connect the woofers in parallel? This means that they will not affect eachother electrically if you use a voltage source (read typicall solid state amp).
By using separate volumes you don't need to worry about any mechanical/acoustic imbalances either.
Things is that if the woofers is not identical regarding small signal parameters they will load eachother mechanically.
The effect (if any) would likely be small though.
/Peter
gedlee 20th February 2009 11:52 PM
I was simply thinking of less wood taking up space, nothing profound.
Defo 21st February 2009 01:45 AM
Yep, they are both fed by the same signal. Will use the same chamber then. Thanks! :)
badman 21st February 2009 03:54 AM
Awww, mannnn!! I was hoping you'd say something about reflected sound through the cone :clown:
Resources saved on this page: MySQL 18.75%
Copyright ©1999-2017 diyAudio
