planning to embark on my first journey into DIY speaker bldg and was wondering if the dayton rs180s-8 would perform as good as the css-sdx7 in a 2 way enclosure for music and home theater. there are just so many combinations to choose from and being totally a noob at this i would ask for advice from those in the know.
i really like the way the sdx7 looks compared to the dayton's stealth look but performance will come before looks. i don't know enough to understand all the specifications listed on the css site for the sdx7 compared to the dayton specs on the parts express site. ? http://www.creativesound.ca/details.php?model=MTM7FIN i aspire to this above linked system but a set of those are a budget breaker for my first foray. i am currently using an old bose acoustimass 5 2.1 that i added a bose center channel and two bose 161's for the rear. while it performs well for our use and is unobtrusive i am ready for some great looking and great sounding speakers to go with my new plasma. a two way tower or smaller enclosure on a stand are what i am looking to build. i have spent a couple of weeks looking at all the systems all here have built and am amazed at what i see.!!! thanks for any info you can lend as i start my first build. oh, i am using a Yamaha RX-V463 HT / receiver to power my system. my older Denon was too big to fit in the new low profile cabinet we have all the appliances in. |
#2 |
You want an SDX-7 equivalent that's affordable? Think Silver Flute
Cheers! |
#3 | |
http://www.rjbaudio.com/Audiofiles/FRDtools.html
http://www.geocities.com/woove99/Spk...esigningXO.htm http://www.zaphaudio.com/ http://www.rjbaudio.com/projects.html http://www.geocities.com/woove99/Spkrbldg/ http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm http://htguide.com/forum/forumdisplay.php4?f=39 http://www.humblehomemadehifi.com/ Hi, Choosing something from the above would make life easier. Quote:
#4 |
sreten, geek,
thanks for those great links. some i have looked at and some were a surprise and exactly what i was looking for. !! i will be doing lots of reading this weekend then. |
#5 | |
Hi, Are silverflutes comparable or even approaches the performance of sdx-7? |
#6 | |
I've heard them side by side with the same program material and while the sdx-7 does go lower and handle higher power levels, for 50 watts and under, the Silver Flute will match it pretty close. In my experiments, the SF W14RC25 likes a 12L ported cab and easily hits 40Hz. The sdx-7 it was in a test with must have been in a ~200L cab. Given the price difference, the SF is a stupidly great driver. I have it as the woofer in a 2-way with a Jx6t and it's a perfect match. Cheers! |
#7 |
Geek,
that part # is no longer a good number at least at madisound but they did have other 6.5 in. shielded woofers. thanks |
#8 | |
Shows up for me http://www.madisound.com/catalog/adv...1&inc_subcat=1 |
#9 |
i copied and pasted the SF W14RC25 designation in their search engine on their site and it didn't like the SF in the part # that is why i didn't see it the first time. thanks
#10 |
I am going to be using 2 silver flute of the 4 ohm version in parallel in separate cabinet comparment in a tmtm configuration using
Vifa XT25TG30-04 1" Ring Radiator Tweeter and a bose tweeter I would appreciate any information you can give enclosed cabinet size w 26.4 cm x H 16.5 cm x d 15.25 cm xover 3k , 12k |
| Lousy woofer choice? help! | 14G-Dutch^ | Multi-Way | 17 | 4th August 2010 09:25 AM |
| Woofer choice for small cab | PeteMcK | Multi-Way | 8 | 12th June 2009 04:48 AM |
| 10" woofer choice | Sypher | Multi-Way | 48 | 10th January 2008 05:38 PM |
| your choice of amp for 2 woofer 15in | ostie01 | Solid State | 9 | 1st August 2006 12:54 PM |
| Mid-Woofer choice | Audist | Multi-Way | 0 | 9th January 2005 10:49 PM |
| Page generated in 0.10596 seconds (81.83% PHP - 18.17% MySQL) with 11 queries |
