last project
last project
Old 19th February 2009, 09:45 PM   #11
dlneubec is offline dlneubec  United States
Very impressive job! Simply beautiful work.
Dan N.
Old 19th February 2009, 10:19 PM   #12
wigginjs is offline wigginjs  United States
wigginjs's Avatar
Do you mind sharing you veneering technique?
Old 20th February 2009, 01:24 AM   #13
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Spectacular!
Old 20th February 2009, 01:30 AM   #14
trusound is offline trusound  United States
trusound's Avatar
Send a message via AIM to trusound
veneering is easy.. infact that was my first attempt..
use non backed veneer
you need:
yellow wood glue, normal clothes iron, old t-shirt, hand held porter cable trim router with flush trim bit, brush sponge.
first study the piece and figure oout were the seams are less visable.. then I took the bottom cabinet, I traced the sides-front-back-top on the venner and cut it with a sharp knife about a hald inch wider than it needed to be. it ended up being 5 pieces per cabinet
I then took the yellow wood glue and the brush spnge and placed a layer on both the veneer and the box and let dry. be sure to anchor the veneer since it will have a tendancy to curl.
once the glue is dry, with the iron and a t-shirt work form the center out to the edges. the heat from the iron flashes the glue and creates a rock hard bond. I spend a little more time on the edges that way it won't chip while routering..
then the traditional sand..sandseal.... then spray on polly
Randy Kunin
www.randall-k.com
Old 24th February 2009, 06:22 PM   #15
simon182 is offline simon182  United Kingdom
now that is what i call quite awesome! well done!
last projectHide this!Advertise here!
CDPRO2 Group Project (open source project) BrianGT Digital Source 147 8th August 2008 11:37 AM
My OLD Project....... cheap tube audio project!!! tube-lover Tubes / Valves 4 8th May 2008 09:26 PM
first project ceebmoj Full Range 5 23rd January 2008 07:51 AM
My first project, cool project. sorinsistem Solid State 3 19th January 2006 05:08 PM
Copyright ©1999-2017 diyAudio
