Routing for non-round speakers - Page 2 - diyAudio
Old 19th February 2009, 01:40 PM   #11
This is my preferred method for odd shaped drivers, it's straightforward and produces very good results.
Simply measure from the outside edge of the router bit to the outside edge of the template guide, and let's just assume this is 1/8". Now find a washer, (or anything round with a hole in the middle), that measures 1/8" from the inside edge to the outside edge. Put the driver onto the template material, put the washer up to the driver frame, put your pencil in the washer hole and roll in around the driver. Once cut, the template will produce exactly the correct cut-out for the driver. Use a washer that is a tiny bit wider, rather than smaller, so that the cut-out isn't a too tight.
Steve
PCB Routing Mark245 Parts 15 27th May 2009 07:54 PM
MDF cnc routing dhole Multi-Way 1 21st January 2006 04:38 PM
Who is the person with round speakers/enclosures on avatar? sqlkev Multi-Way 10 25th January 2005 11:52 PM
4" all round speakers Mani691 Multi-Way 7 3rd August 2004 11:46 PM
Round speakers jouch Multi-Way 12 5th December 2001 08:37 AM
Copyright 1999-2017 diyAudio
