My xover board is buzzing!
Old 17th February 2009, 08:46 PM   #1
bastek is offline bastek  United States
Default My xover board is buzzing!
I was checking the woofer section of my Sigmas and playing with stuffing. With the woofer still connected but out of the cabinet, i noticed a buzzing sound in sync with the music coming from the woofer x/o board which is separate from the mid-high section, with separate input posts. This happens only with the volume at about 11-12 o'clock position, if i go any higher the amp goes into protection mode. Both left and right speakers make the noise. Is this normal? Note that i can hear distortion from the woofer before the crossover starts buzzing.
Old 17th February 2009, 09:11 PM   #2
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
If your crossover has ferrite core inductors (anything that isn't air core), it's possible that you are saturating the core, which will cause the inductor to vibrate.
Recommendation: turn it down!
The power of Science compels you!
Old 18th February 2009, 05:51 PM   #3
Pano is offline Pano  United States
Pano's Avatar
Yep - coils will sing! I've heard it before. (But not with aircore, IIRC). - - As Dcibel mentions.
Are they aircore?
Old 18th February 2009, 08:25 PM   #4
knorke is offline knorke  Germany
knorke's Avatar
Air coils will sing to. The windings will vibrate due to magnetic forces. Foil capacitors sing also, the foil vibrates due to electrostatic forces. Hook up a coil or
cap with a series resistor directly to the amp, crank up
the volume. You will hear the (distorted) music!
What do we learn: mechanical stability of crossover parts is important.
My xover board is buzzing!Hide this!Advertise here!
Sure Electronics New Tripath Board 4*100W class-D Amplifier Board 7788q Class D 354 17th March 2017 01:19 PM
Buzzing Pre-amp stevebell Solid State 10 12th June 2008 03:26 PM
My Cambridge 500SE, needs an output board (to replace internal DAC Board) slbender Digital Source 0 15th May 2008 01:36 AM
buzzing problems specter73 Solid State 13 28th October 2005 07:46 AM
Buzzing in A40 NickC Pass Labs 9 25th August 2003 11:42 AM
