I have a pair of 21W54 and a pair of 30W54 Dynaudio woofers that need the foam surrounds replaced.
I have searched the archives, but many of the discussions that I have read are dated, and I need more current opinions. I'm not afraid to tackle the job. However, I am leery of some of the surround kits out there and I don't know which ones are reliable, or which vendors are reliable. I also want the correct size surrounds, and not some one size kinda sorta fits all surrounds. I have heard that the newer foam materials will last longer than the original, so I don't want ancient surplus foam surrounds. I'm not opposed to butyl rubber surrounds if they don't adversely affect the sonics. I'm asking for opinions on using foam versus butyl rubber surrounds for this specific application. I'm also looking for reliable vendors to buy the surrounds from. If it costs a little more to buy the correct surrounds I'm willing to pay for it. However I don't want to waste my time and money on cheap crap that I will have to replace again before it's time. Your advice will be appreciated. Scott Novak |
#2 |
The title says it all. They claim to have new foam kits for your dynaudio woofers with the original specs - possibly made by Dynaudio. Found them by googling "dynaudio refoam", however, I did not buy. Too expensive for my kit loudspeakers.
Good luck. |
#3 |
You can use a slightly larger rubber surround and cut it . Overlap about 1cm and glue the edges together with a rubber based glue. Cut it at an angle and not at 90 degrees to the edge.
We did this about 10 years ago and drivers are still fine today. TS parameters changed a bit with Fs going down a bit. It works without a problem in the same enclosure. The rubber surround was bought from some company in the US. Don't recall it's name.
AM |
#4 |
Uhhh guys, the OP was 2 years ago, I doubt he's still waiting to get them refoamed
| crossover for dynaudio D-21, D-54 and 30W54 set | Filip89 | Full Range | 0 | 8th August 2009 04:58 PM |
| Dynaudio 30W54 12inch woofers | hottyson | Swap Meet | 2 | 18th August 2008 08:49 PM |
| woofers Dynaudio 30W54 | Josep | Swap Meet | 0 | 20th April 2006 11:27 PM |
| Dynaudio 30W54 | Josep | Swap Meet | 0 | 19th March 2006 05:56 PM |
| WTB: Dynaudio 21W54 8' Woofers | bng | Swap Meet | 0 | 20th April 2002 03:21 AM |
| Page generated in 0.08245 seconds (77.61% PHP - 22.39% MySQL) with 10 queries |
