Near-wall design - Page 2 - diyAudio
Old 17th February 2009, 07:34 AM   #11
Pan is offline Pan  Sweden
David,
have you considered a 300-400Hz crossing?
It would fill out the "floor dip", increase dynamics/reduce distortion and possibly give less problems with phase distortion in the 100-250Hz range which have shown to be an area of increased sensitivity to groupdelay.
/Peter
Old 17th February 2009, 11:50 AM   #12
56oval is offline 56oval  Australia
Originally posted by David Gatti
Nice to see 56oval. What's the dimensions & drivers you're using?
Why did you choose 70 degrees? A lower angle would help with diffraction.
Hi david
The front baffle 300mm wide,700mm high & its @ 250mm deep I think .
Drivers 1st you can't please everyone so here goes
Raven R1 ,6.5"PHL 1120 & 10"PHL3020 bass I haven't decided it might be a 15" or maybe try multi subs .
The 70 to 72 degree angle came from a totally different industry and I know someone who has tried it and it worked ,most likely 50mm roll over could work just the same and easier .
Cheers
Mal
Old 17th February 2009, 11:08 PM   #13
David Gatti's Avatar
Originally posted by Pan
David,
/Peter
Yes Pan, at this early stage, I'm considering anywhere from 200 - 400 Hz.
I will have to do some simulations, and also figure out the optimum height for the woofer. Any suggestions on that? I'm in 2 minds, thinking fairly high for the best integration with the midrange (1st order crossover), but closer to floor for less floor bounce in the midrange.
560val, sounds like quite a nice efficient design. When do you start making sawdust?
Old 17th February 2009, 11:44 PM   #14
When I stop looking at more efficient design's and cabinet materials .
Cheers
Old 18th February 2009, 12:39 AM   #15
My next (re)build will be similar too - simply because I don't have the facilities to build Troels' PMS...
My last two builds used the same drivers, one in 300mm pipes, the other in wide but thin cabs, 500x170 - it was much easier to get BSC & driver balance right in the wide cabs (& they suit available space better)
I'm rebuilding my all Peerless system, (drivers from before the move to China) 3 way, this will be bi-amped, current xover 200Hz 1st order passive, but on Pan's suggestion I'll try higher.
I want to get the Baffle width & xover freq 'co-ordinated' so that I can tweak BSC simply by changing the level on the woofer amp
re 'optimum height for the woofer' - I don't like woofers too close to the floor, I seems to muddy up the sound a bit to me.
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 18th February 2009, 12:48 AM   #16
Bi-amping would be nice, and I leave that as an optional upgrade further down the track.
I agree about the bass driver close to the floor tending to muddy the sound, and I suspect that's more about crossover interaction rather than floor bounce. Since the 12" woofer already has a 6cm or so depth, then you add the increased path length to the listener's ear, it's tough to compensate for it in the crossover.
CCS FR125S Options for a wall mounted design? BL21DE3 Full Range 13 25th March 2006 10:42 AM
in-wall speaker design exipnos Multi-Way 7 14th November 2005 12:56 PM
Copyright 1999-2017 diyAudio
