Old 16th February 2009, 06:37 PM   #11
Dr.EM is offline Dr.EM  United Kingdom
Dr.EM's Avatar
Is the best way to ensure things are aligned well to install the drivers in the baffle/enclosure and play a tone at crossover frequency with one driver out of phase. Then adjust the delay/phase for maximum null before putting the polarity back as it should be? Microphone presumably lined up at listening posistion/tweeter height. Driver output levels would need to be matched without moving the mic first.
Old 16th February 2009, 06:51 PM   #12
No, not if you want best time alignment. That ensures good phase alignment, but you could be a full wavelength apart (or some other multiple). I'd play a sine wave at the crossover frequency and look at the difference in delay for each speaker from an electrical reference (the reference signal in a two channel measurement setup). Line them up that way and then fine tune using reversed phase.
Old 16th February 2009, 07:32 PM   #13
Dr.EM's Avatar
Ok, yes, I understand
I am unlikely to be a full wavelength or more out with my driver arrangements so that should be fine. The crossover will mess up time alignment if it's 24db LR anyhow, I think? Phase alignment is probably what I'm after really.
voice coil rubbing? Dr.H Multi-Way 2 29th January 2009 01:57 PM
Single Voice Coil Vs Double Voice Coil Subwoofer Workhorse Car Audio 6 12th April 2007 06:36 AM
ASV voice coil ? Nihilist Multi-Way 4 1st October 2006 07:16 PM
an amp for each voice coil? speekergeek Multi-Way 1 12th December 2003 02:31 AM
blown voice coil krimet420 Multi-Way 3 10th December 2003 02:30 PM
Copyright ©1999-2013 diyAudio
