Need advice for next project -  should I go fullrange or multi-way?
Old 16th February 2009, 01:07 AM   #11
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally posted by Bubba Zanetti
And then I realized: "gee, I'm building 3-way fullrange system, am I an idiot or what ?...
Verdict: Fullrange - yes, but only in multi-way combination
I have been an advocate of this kind of thing all along. But i firmly believe that if you start with a "midrange" that by itself can give you a musical system then you are way ahead of a typical multi-way system... the XO(s) can be pushed out to where they are much less objectionable.
My big Fostex system has fonkenWoof with 2 SDX7 XOed at 100 Hz to FonkenPrime with FE127eN. I have been playing with supertweeters up above 15k, i haven't gotten far enuff to decide whether they'd be missed.
With Tysen the little "FR" extends well beyond 20 k (Fostex spec 32k), and bottom down below 40, and imagine like crazy (but then so does the big system)
Llistening to stock Fostex in no way reveals how good these drivers can be.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th February 2009, 05:58 AM   #12
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Hard to say it better than that.
Cheers
planet10 needs your help:
Let's help Ruth and Dave
Old 16th February 2009, 07:22 AM   #13
DaveCan is offline DaveCan  Canada
DaveCan's Avatar
These are just outside your budget by a bit. Not a full range and not multi-way, but a nice compromise maybe?.. You would be one of the first to try them though if you went this route.. http://www.greatplainsaudio.com/downloads/212_8A.pdf Dave
Old 16th February 2009, 07:42 PM   #14
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
I forgot to ask you - what music are you listening?
all kinds of music, classical, 80's, jazz, blues, metal..
imho you'll never miss a tweeter with the Alapir5 (or the A6), frequency extends far beyond 20kHz and directivity is not a problem as it is with the larger FRs
and with a woofer like the SDX7 in a TL you'll certainly never need a subwoofer for music.
the Tysen concept might just be what you are looking for...
Old 16th February 2009, 08:19 PM   #15
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Anyone tried a design like this, with all same small FR...wwmtm
Only 2 inductors fore 300/1khz 6db lowpass is used...but maybe also a 1khz 6db highpass on "tweeter" driver
sometimes we know very little, and sometimes we know too much
Need advice for next project -  should I go fullrange or multi-way?Hide this!Advertise here!
Advice sought on building multi-channel amplification jwillans Solid State 10 3rd March 2009 09:31 PM
Bookshelf fullrange advice wanted Rocky Full Range 56 26th June 2006 03:10 PM
Multi purpose multi channel gainclone PCB: Team project - group buy rick57 Chip Amps 14 29th March 2003 06:54 PM
