bass nulls
bass nulls
Old 17th February 2009, 03:07 PM   #21
GM is offline GM  United States
GM's Avatar
Unfortunately, it will require you to 'map' the TL's construction if you don't have its construction details along with measuring the driver's T/S specs outside the cab to give us a good chance at a one time 'fix'. Otherwise it will require you to do probably considerable experimentation to get it right, so all things considered it may be best overall to just seal them up and add a sub system to fill in the extreme bottom.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 18th February 2009, 04:24 AM   #22
JLC7 is offline JLC7  United States
Update on the speakers.
Moving them into another side of the room and close into corners seems to help a lot. When they are away from the side walls I get what I had before.
Here's the plot vs. my diy design both at listening position.
Steve continues to amaze me.
bass nullsHide this!Advertise here!
Horizontal MTM Center channel: avoiding off-axis nulls DcibeL Multi-Way 27 10th October 2009 05:57 PM
Where are peaks and nulls most offensive valleyman Full Range 3 21st November 2008 05:00 PM
any electric bass players? im building a bass guitar cab KOA Instruments and Amps 27 30th April 2007 03:49 PM
DBA (dual bass arrays) and active bass traps capslock Subwoofers 3 20th August 2006 12:52 PM
For all Bass Junkies out there (Behringer Bass processor usage report) VEC7OR Digital Line Level 5 27th October 2003 09:18 AM
Copyright ©1999-2017 diyAudio
