Three questions that I cannot find good, definative answers for:
(Perhaps I'm not using the right search terms....) 1) Why a seperate tweeter enclosure (like the swans and the Wharfedale Evo2)? I believe that the designers are taking the tweeter off the baffel....why? 2) Why two mid/woofers? Especially when both use the same XO? I've seen them in MTM and TMM configurations. I looked for this one and found better off axis performance but is that all? 3) Why the asymetrical placement of speakers on the baffle? |
#2 |
1. Diffraction.
2. Vertical polar pattern and lower distortion at higher SPL. 3. Diffraction. The placement of drivers on a baffle causes frequency response irregularities; items 1 and 3 are generally attempts to minimize these effects. There are some excellent freeware programs which allow you to calculate the effect of driver position on the baffle on frequency response- FRD Consortium has published several that I've used, and they are very educational to play with.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
TMM is also a 2.5 way, as opposed to the 2 way for MTM - one woofer is midbass and the second is usually a first order electrical bass.
Soft Dome |
| Some Quad els57 questions! - Novice Questions! | Fanuc | Planars & Exotics | 13 | 5th December 2007 09:26 AM |
| A2 Questions | Svetlana | Tubes / Valves | 16 | 1st September 2006 02:37 PM |
| sub questions | kejolly | Subwoofers | 1 | 3rd November 2005 01:17 PM |
| Questions, questions, from newb DIYer | Phatman91624 | Multi-Way | 41 | 3rd August 2002 02:52 AM |
| Page generated in 0.08239 seconds (73.02% PHP - 26.98% MySQL) with 10 queries |
