Old 12th February 2009, 12:38 PM   #1
Default ARTA help
I would like to start testing my speaker design. I have the ECM8000, Tasco Links USB Phantom Power box, SoundBlaster X-Fi sound card, Atma-Sphere all balanced pre and power amps. The power amp will take an RCA input.
The sound card only has 1 (mic) input, and 3 outputs. All mini plugs.
Am I safe in assuming I use the monitor out of the Tasco to the mic in of the sound card?, or should I use the headphones out on the Tasco?.
If I am reading the ARTA manual correctly, I need a cable to go from the soundcard out and into the power amplifier. Am I safe in assuming I need to make a cable which is mini plug at one end, and RCA out at the other?.
Is the ARTA measuring box a good investment, and where would I get one?.
The voltmeter's I can find all have two prongs. Is there a concesus on the best type of electronic voltmeter to use?. Will I need to redo the measuring ends?.
Thanking you all in advance. Bill
Old 12th February 2009, 03:38 PM   #2
http://tech.groups.yahoo.com/group/arta_users/
Old 13th February 2009, 12:16 AM   #3
I use this simple jig:
ARTA Jig - http://zobsky.blogspot.com/2008/01/s...t-jig-for.html
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
ARTA ente Multi-Way 150 25th December 2012 04:35 PM
newb ARTA calibration ? Kepler Multi-Way 3 4th May 2011 10:21 PM
ARTA calibration help augerpro Multi-Way 5 14th June 2009 10:11 PM
Arta Asio doylep Multi-Way 4 19th May 2009 02:11 PM
Arta is SWEET!! ch83575 Multi-Way 7 23rd February 2007 12:27 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
