Hi there.
Im planning on building myself some speakers, If I run my plans past you, you can tell me if im heading in the right direction as in doing my research for this project I found speakers aren't as simple as I first thought! So what I propose is MDF Boxes, (I Reckon 18mm?) Running 15" drivers for bass, 10" For mids. Does that sound ok? Im unsure what my options are, as far as tweeters o. What are the pros/cons of bullets or piezo horns? Can I use a shop bought 3 way crossover to seperate the signal between the speakers? Should I port the boxes for better bass? Is there anything I can do to help get the best from the drivers I buy, e.g soundproofing or something? Cheers, Rob. |
#2 |
Hi Rob
I like big woofers so I have no problem with you using 15 inch for bass duties. What you are asking though is a set of inter-related questions the answers to which are dependent on the driver selection. Personally I like sealed boxes with relatively high "Q" drivers for sub-woofer duty. Ported boxes need a bigger box to perform well and usually use a driver with a lower "Q" and there are drivers which can be used in either type of box 10 inch mid-bass and mid-range is do-able although the usual approach would perhaps see a compression driver taking over very low. The classical approach would probably see a 6 inch mid-range crossed over quite low and using a tweeter from about ( and these are fuzzy figures) 2500Hz NO to the shop bought XO and I don't like piezoelectric tweeters (others do) There is always things you can do to improve the performance of the combination of box,driver and crossover, starting with adequate bracing acoustic damping and using good components in the XO and good driver selection. I would suggest that before you delve any further into the question you do some research, read some books and read thruogh a few of the threads on here. Go to a local HiFi store and see/hear what you can get for your money and set a budget. Most people here are willing to help, but not every-one has the same opinion and we need you to provide as much relevant information as you can. Even the question regarding MDF as a box material can open a can of worms, do a search for the threads on what makes the best box, it runs for hundreds of posts and dozens of opinions. I have used different materials for boxes most based on cost, MDF is OK so is a combination of MDF and other materials. Read the threads and be prepared for a lot of trial and error Simple NO!! Fascinating & addictive YES!!! Regards Ted
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#3 |
If you buy full range 10 inch speakers you shouldnt need tweeters.
I have a 4 by 10 inch cabinet that is full range on its own. But I use it in conjunction with an 18 inch driver to get the extra bass I like. Bluearan.co.uk do a fantastic range of speakers ate good prices. Thats where I bought mine.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#4 |
You are facing a number of difficulties, adapting pro drivers fore domestic use
Active crossover is really not my cup of tea, but it might be your best shot to make it work Use 18" woofer B&C 18PS100 in 150liter BR would work Double Eminence Alpha-6A might work with a "slot" tweeter Or maybe better consider a "ribbon" like Hivi PLANAR RT2-pro |
#5 |
Examples from the designs of others can be quite instructive:
http://www.zaphaudio.com/ http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm http://www.rjbaudio.com/projects.html http://www.humblehomemadehifi.com/ ask heaps of questions here
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#6 |
Yeah, speaker design is a strange black art. It seems pretty reasonable and simple at first, but the more you learn about how it works, the more confusing it gets. We were all there at one time.
http://undefinition.googlepages.com/diy-mfaq |
#7 |
Cheers for the help,
I'm looking forward to this as i have access to a carpentry workshop over the weekends. the music the speakers will mostly be playing is drum and bass, Hence the need for Huge bass sounds without distortion Tempted by some 24" drivers haha! If i was made of money.... |
#8 |
Reading Undefinitions FAQ'S I realise the cabinets & crossovers are better being designed around the drivers.
being a (Trainee) electronics engineer, I have no problem designing and making cicuits, have built high / low pass filters, and Im sure I could tackle a 3 way cross-over after the appropriate research. My question is, how do I calculate the corner frequency i need in relation to the drivers I buy? how do i know if the Q value is enough to justify ported boxes? |
#9 | |
Crossover is the hard part and will never get easy To evaluate the driver is the easy part Sim a lot of drivers and you will soon find what specs you need...or simply invent a driver and change its specs, and see what happens And you may quickly realise that the driver you want, doesnt exist |
#10 | |
Now, I respect that fact that you're a drum & bass fan (from England, no less. The land of the best electronic music on the planet!). (BTW: you'll notice that I've written quite a bit of my own drum & bass if you look around my site) You would probably have a blast desinging your own sub as a first project. It's an excellent way to get the hang of tuning an enclosure. Yes, you can tell from a driver's Qts whether it will work better sealed or vented. And using some free box modeling software, you can find out how large of a box you'll need to get your desired F3 (or if the woofers you've chosen can even reach the level of bass extension you think you can). You'd be surprised to find out that you can pretty much get down to subterranean depths (we're talking 20 Hz here) using only a 10" woofer--in the properly tuned box. In fact, some 8" woofers can also get you down into the mid 20's without much trouble. So basically, the advantage of a really big woofer at that point is simply that it has more surface area and can "move more air" and thus deliver more SPL; but it won't necessarily go any deeper. Also, the bigger the woofer, the larger the required enclosure needs to be. Here are the two most commonly used box modeling programs. Plug in the T/S values for your desired woofers and play around and see what kind of bass extension you can get: unibox (my personal favorite): http://audio.claub.net/software/kougaard/ubmodel.html WinISD: http://www.linearteam.dk/default.aspx?pageid=winisdpro |
| Page generated in 0.11280 seconds (86.17% PHP - 13.83% MySQL) with 9 queries |
