Audio Junkie
I just picked up a 15" Stromberg Carlson Custom 400 wide range speaker. It appears to be a coax and there is a capacitor mounted to the frame near the spider. there is also a plug on the side that i would bet is for an attenuator but i did not get that part.
Anyone have any info on these or websites?? I couldn't find much on Google. Man i wish i had a pair of these! They are very cool! I need to figure out the wiring of the HF unit and the plug on the side and what not... |
#2 |
Audio Junkie
#3 |
Audio Junkie
i figured SOMEBODY would know something about these???
#4 |
Audio Junkie
I Finally found some info!!! This is a 1950's S-C Model RF-465 speaker. the number stamped on the cone I believe indicates 1955. I found a brochure from 57 that has this speaker listed with the following info:
15" Speaker Model RF-465 The "Omega M" Speaker is our supreme offering to you who know quality when you hear it...and are not immune to a bargain when you see it. Advanced engineering has gone into the perfection of this wonder of hi-fi, enabling Stromberg-Carlson to produce a superior high-fidelity speaker below the cost...but above the performance of competition. General Specifications True coaxial speaker system with "Omega M-Voice Ring" horn loaded 2-1/2" Tweeter and separate 15" low frequency woofer...Moisture resistant cone...Frequency Response; 30 to 20,000cps...Power-Handling capacity: 35 watts of program material...Better than 90 degrees angle of coverage...Brilliance control provides variable control of high-frequency response. Engineered to match perfectly any type of enclosure suitable for use with a 15" speaker. Total magnetic flux at voice-coils is 20,000 gauss. Medium efficiency but extreme range. http://www.audiophool.cjb.net/Misc/stromberg_57.djvu |
#5 |
Interesting! Wasn't aware of this site, thanks! I'll have to install the viewer though. My S-C driver experience is limited to the Slimline 15" co-ax. I'm surprised Freddy didn't respond, he's a wealth of vintage info, so give him a jingle: http://www.diyaudio.com/forums/membe...o&userid=50859
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
| Stromberg-Carlson ASR-433 | Bran Kulez | Tubes / Valves | 10 | 20th October 2009 07:23 AM |
| Stromberg Carlson ASR 533 | kc5scs | Everything Else | 0 | 22nd January 2008 02:58 AM |
| Stromberg Carlson speaker...please help. | the_manta | Multi-Way | 5 | 7th March 2007 02:20 AM |
| Stromberg Carlson 245M | Original Burnedfingers | Tubes / Valves | 6 | 12th August 2004 02:04 AM |
| Stromberg-Carlson 15" Coaxial | thetubeguy1954 | Multi-Way | 18 | 13th June 2004 01:29 PM |
| Page generated in 0.09203 seconds (72.88% PHP - 27.12% MySQL) with 10 queries |
