Soldering Tips
Soldering Tips
Old 13th February 2009, 03:47 PM   #21
madisonears is offline madisonears  United States
If this is your first attempt at soldering, don't try it on the actual speakers. Buy a cheap terminal strip and practice soldering some spare wire to that first. You'll get the hang of it after a couple tries. Then you'll be ready to solder onto those fine drivers. Why risk wrecking one or making a crappy solder joint where it counts most?
Soldering is VERY easy, but, like any other skill, takes just a little practice to get right.
Peace,
Tom E
Old 14th February 2009, 10:22 AM   #22
Stuey is offline Stuey  Australia
Thanks Ted, I'm going to have a look round for that. I've seen Multicore around; just can't remember where!
Old 14th February 2009, 02:57 PM   #23
Pan is offline Pan  Sweden
Originally posted by Moondog55
I can add one thing, use a good quality solder
Personal experience says avoid Lead-free solder as I have found it makes extremely poor joints
It's a little tricky if you switch from lead soldering without adapting to the new situation. Using the right tools, temparature and solder makes for 100% perfect lead free solder joints though.
/Peter
Old 14th February 2009, 08:04 PM   #24
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
Hi Peter, that may be true, buy I have not found it so, perhaps my joints were contaminated by traces of a lead solder or were pre-tinned at the factory which makes using a lead free solder problematic.
It is interesting however that all military soldering is still done with 50/50 lead solder due to the poor reliability of the alternatives
regards
Ted
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 14th February 2009, 08:32 PM   #25
nickmckinney is offline nickmckinney  Barbados
diyAudio Member RIP
One trick I learned soldering aircraft in the military is always leave a blob of solder on the tip when its not in use. I have had tips last 5 years that were used almost everyday doing this. If the tip cannot become smooth and shiny with *no* solder right after you wipe it in a wet sponge then its a tip I don't want to use. The blob job works good, when you go to use the iron just tap it against something for the blob to fall off, wipe on a wet sponge, and you have a perfect shiny tip ready to go.
Old 14th February 2009, 10:49 PM   #26
Wet sponge is not good with leadfree. It's even more important to keep the tip tinned using LF solder since the "wetability" is worse than for leaded. When you wipe the tip at a wet/damp sponge it becomes way to clean and oxidation sets in quick.
Oxidation also increases with temperature and normally one is using a slightly higher temp with LF.
The recommendation is to use a special kind of steel wool and/or a salmiak stone, that makes the trick.
Also it's important to find the right LF solder for the job.
When using RoHS parts and LF solder and the above described techniques it works fine.
The reliability of LF joints are fine for most use and studies has shown it to be even better than leaded on several parameters.
The alarming reports use to be about companies that have done mistakes when switching over to LF or whiskers growing on some components/circuit boards casuing shorts and malfunction. AFAIK it's not LF as such that casue whiskers but the use of electro plated parts.
If memory serves me (I think there has been in depth discussion here at DIY about this earlier) this can be avoided by heating up and tin the surfaces with solder during assembly/soldering.
Something like that! :-)
/Peter
Old 14th February 2009, 10:52 PM   #27
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
In other words: lead free sucks.
It's only audio. Member of the non modular PCB design committee
Old 14th February 2009, 11:21 PM   #28
454Casull is offline 454Casull  Canada
Yep. I gotta stock up.
Soldering TipsHide this!Advertise here!
Building tips please!!! HaLo6 Multi-Way 6 1st March 2009 04:41 PM
Tips for AD797 ?? redrabbit Everything Else 11 2nd October 2008 04:55 PM
st-70 questions... tips? hi_im_sean Tubes / Valves 5 11th July 2005 01:47 AM
Anyone have tips for DIY caps? JoeBob Parts 6 30th January 2003 02:22 AM
