#2 |
#3 |
#4 |
#5 |
What TB speakers are you using?
Aggressively Passive |
#6 |
http://www.parts-express.com/pe/show...number=264-826
Tang Band W5-876SD 5" Shielded Subwoofer If you look in the pdf I supplied on the crossover stuff it has the dirver information and the crossover setup I'm using. |
#7 |
Not terrible cabinets, I rather like slot ports, but are you serious about your driver selection and crossover? This can't sound good.
Katana2112, he is using TB W5-876SD 5" subwoofer, and a Dayton ND28F-6 tweeter.
The power of Science compels you! |
#8 |
Why would you think that it would not sound good? That speaker is also used as a midbass.
#9 | |
actually the nd28f-6 is the 8 ohm not the 6 ohm |
#10 | |
-You're tweeter response shows that it's working fairly hard down to 1kHz. Probably not a good idea for something that costs $15. -You haven't matched the driver sensitivities in the crossover -You're crossover has not taken the impedance of the tweeter into account. ("impedance" and "nominal impedance" are not the same!) -et cetera
| Unity Horn Project Progress | Sheldon | Multi-Way | 16 | 8th February 2007 04:18 AM |
| This project is in progress | fung | Multi-Way | 14 | 10th April 2006 06:49 AM |
| Project progress report | Magura | Parts | 24 | 11th March 2005 07:56 PM |
| My 15" Sub - Project in progress | Matttcattt | Subwoofers | 38 | 19th April 2004 06:05 PM |
| Senon YD1256U OB-project in progress | Mattias S | Multi-Way | 4 | 14th April 2004 01:03 AM |
| Page generated in 0.11051 seconds (79.56% PHP - 20.44% MySQL) with 10 queries |
