My TL/Bi-Amped Powered Speaker Project
Old 11th February 2009, 12:12 AM   #11
Nedrex is offline Nedrex  United States
Originally posted by planet10
that's what i like ... a guy who just knows he is going to become an addict
dave
Ha! Yeah.... well, I'm afraid it's a bit too late for that. I've been designing and building speakers since I was a teenager (28 now). So I'm already hooked... I was just in remission for a while, this little project is my return to the art. And I'm quite glad to be back!
Back OT... does anyone have any thoughts on the early reflections or impedance/output shaping networks? I'm planning on finishing these things up soon and would like to put these two things to bed (if only in my mind) before it's all buttoned up.
Old 11th February 2009, 04:48 AM   #12
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Relections -- internal & external -- are best dealt with at the source.
Probably the most commonly used response shaping filters are forbaffle step.
I personally try to avoid them as much as possible, but they can be useful.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th February 2009, 12:05 AM   #13
I see, so it sounds like you're telling me that if I plan on doing anything about issues with early reflections (if they arrive) I should handle it with DSP processing? Is that what you meant by the source? Or do you mean I should deal with it by altering the placement of the tweeter?
What would you gauge as "more important": time-aligning the drivers, or placing the tweeter so as to avoid early reflections as much as possible? Choosing the second option will place the tweeters acoustic center about 2.5 - 4.5 cm in front of the woofers.
Old 15th February 2009, 01:04 AM   #14
frugal-phile(tm)
planet10's Avatar
DSP can't do anything about an early reflection. Inside a speaker you deal with it using damping (and maybe some subtler tricks) ... same with external refletions.
I don't have to deal with the former, i abandoned traditional multiways a long time ago...
dave
Old 18th February 2009, 01:08 AM   #15
Thumbs up Update...
Hey all! Got a good amount of work done this weekend:
- Holes were drilled to countersink the magnets that will hold the grill up.
- Front, top and rear veneer was installed, trimmed, sanded and stained.
Hmm, doesn't really sound like a good amount of work when you put it that way, does it? Well, whatever it was the cabinets look fantastic. All that's left to do is rattle can the sides, install the amps, woofers and tweeters, and make up the grills. Shouldn't be too bad.
In any case, enjoy the visual aides below. As always: questions, comments or constructive criticisms are welcome!
My TL/Bi-Amped Powered Speaker ProjectHide this!Advertise here!
anybody hacked insignia ns-bt400 amped speaker yet? ke4mcl Class D 1 14th May 2009 08:48 AM
DIY High Efficiency Bi-amped Speaker redesign Jerry Parker Multi-Way 1 6th November 2006 05:28 PM
Q&A - LM4780 type as bi-amped speaker driver FastEddy Chip Amps 5 28th August 2006 08:39 AM
Morel 3-way tri-amped project Joe-Al Multi-Way 0 12th December 2005 04:20 PM
Where to place the amps in bi-amped/tri-amped Xicarius Everything Else 1 4th August 2004 12:13 PM
Copyright ©1999-2017 diyAudio
