Old 8th February 2009, 08:08 AM   #1
Default Where does the baffle end?
When modeling with Edge, which has no provision for radius edges, where does the edge of the baffle end? With a square corner, it's obvious. With smaller radii, as much as an inch, it's still reasonable to say that the flat baffle face stops at the point where the radius begins. However, if using a larger radius, such as 2 or even 3 inches, does one use any portion of that radius on each edge and include it with the flat baffle width? Or is flat always perfectly flat, and any radius, no matter how large, beyond the edge as soon as it starts to curve away from tangential?
Peace,
Tom E
Old 8th February 2009, 08:49 AM   #2
Even when the enclosure is completely round, The baffle width would still be the diameter of the round enclosure. So 2" or 3" radius have no effect on reducing the baffle width for baffle step compensation, When entering the data into a program. It only matters to the high freq.
A study shows that a 12" round enclosure have about 375hz, -3db point of baffle loss, same as a rectangular box of the smae width, The only difference is the smoothness of the highs in the round enclosure
Murphy baffle radios [ open baffle ] keithpeter Full Range 10 11th September 2007 08:59 PM
Does open baffle suffer from baffle step? 454Casull Multi-Way 11 17th July 2006 10:25 PM
what effect does baffle have on open-baffle system? kappa546 Multi-Way 6 24th January 2006 11:21 PM
Australians- what solid timbers for baffle? (open baffle loudspeaker) tktran Multi-Way 13 30th November 2004 12:09 AM
Edge diffraction: large, rounded baffle, or narrow square baffle fortyquid Multi-Way 12 12th January 2004 04:43 AM
Page generated in 0.06897 seconds (72.38% PHP - 27.62% MySQL) with 10 queries
