Old 16th March 2009, 05:26 AM   #31
Originally posted by nukaidee
no point making the port half the size i want my box to be right? and the bigger the port.. the longer the tube and .. yeah. doesn't work.
A tube port of any size is not always practical especially in smaller enclosures but that doesn't mean porting can't be done using, for example, a slotted port built into the cabinet's internal structure.
These ports are usually the same width as the front or rear baffle, tuning is done by varying the height of the slot and the thickness of the baffle and size of internal braces provide depth. Many high-end bookshelf kits use such ports and more than a few large speakers as well. It's too costly for mass-produced cabinets but not much more work for DIY'ers, and it makes for a studier box.
Old 9th May 2009, 09:18 AM   #32
umm.. then how does the sound come out? its just like placing the drivers facing each other, wont that muffle everything? from what I am reading here, there are many ways to mount it. http://www.audiogearreviews.com/tech...n/isobaric.asp
and I'm guessing that isobaric only works for subwoofers and not particularly good for the high ends.. maybe I will mount my subs like this and use a stand alone tweeter.. usually tweeters don't need a big volume right? maybe I can just place one on top like something sticking out?
I built my first succesful iso (clamshell design)
I am using 2 MTX 5500 12" subs in a 3.5 cubic sealed box
Win isd comes back with "down 9.75 db 20-100 hz"
I mounted the drivers on top of the cabinet and put it in in cornor .
It goes real good !
push pull power amp design question (a lot of actually :) ) krusty75 Tubes / Valves 6 25th September 2008 05:07 PM
New design: 12V push-pull tube amplifier engels Tubes / Valves 3 20th September 2007 03:02 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
833 push pull design help sickss Tubes / Valves 19 7th March 2005 03:25 PM
DHT triode push pull amplifier design James D. Tubes / Valves 2 5th December 2002 08:44 AM
Copyright ©1999-2013 diyAudio
