I live in an apartment, and do all my cutting/drilling in my dad's garage, but there's no precision equipment.
I used to get the wood for speakers cut at Home Depot, but now the buggers "do not do precision cuts" and I can't get the teenagers to cut wood satisfactorily. Where can I get mdf cut with reasonable precision for me?
Wherever you go there you are. |
#2 |
Go to a high school and get someone like me who's anal about precision to cut it...cheaper and probably free.
#3 |
Time to buy your Dad some 'precision equipment'. Start with a quality 10" tablesaw.
Have you tried clamping a straight edge like a piece of angle iron to the MDF and using that as a guide to press the skillsaw against as you make the cut? Before I finally got a nice 230 volt, 10" table saw I did a lot of speaker cabinet construction with my old skill saw, including cuts with the blade at a 45 degree and other angles using this technique. The results were excellent. You will also need a pair of saw horses or a large flat bench surface and some portable weights to hold stuff in place while you cut. Cinder blocks make good weights if placed on a rag to prevent scratching.
I.Q.Test. Have you ever purchased a recreational snowmobile? |
#4 |
Yeah I used a bitof 2by4 and tried that but the thirty-five year old saw is getting a little long in the tooth I think... I don't want to invest in a new rotary saw... I'd rather get someone else to do my cutting and then buy a good tablesaw once I have a garage.
My dad lives a ways away so I'm just going to have to wait for my own worshop now I think...
#5 |
What's stopping you from buying a table saw now and setting it up in your apartment long enough to do this speaker job? Once you are done, crank down the blade, put a tablecloth over it and voila, practical kitchen table.
Is there a clause in your lease that specifically prohibits a tablesaw?
#6 |
Any good lumber yard should be able to do this. Or, look for local cabinet and custom woodworking shops.
I used to be an audiophool like you but then I took an arrow to the knee. |
#7 | |
Well my wife would probably... well kill me dead.
#8 | |
#9 |
LOL, seriously, what do you need? If you're desperate enough, I can cut it at my school, then send it to you.
#10 | |
Building a 2.1 system out of a 3/4"x4'x8' sheet |
| Hi from SW Ontario | pollypocket | Introductions | 4 | 23rd July 2010 03:26 AM |
| How to get licence in ontario ? | boris333 | Everything Else | 4 | 26th August 2007 10:11 PM |
| Hello From Central Ontario! | Potsie | Introductions | 3 | 8th August 2006 02:21 PM |
| Hello from Ontario | John Bartley | Introductions | 3 | 5th June 2006 01:32 PM |
| Hi from Ontario, Canada | rcavictim | Introductions | 5 | 30th June 2004 06:30 PM |
| Page generated in 0.10581 seconds (79.00% PHP - 21.00% MySQL) with 11 queries |
