Old 4th February 2009, 02:29 AM   #1
luvdunhill's Avatar
Default Crossover Layout Comments
Hey guys!
I've finally gotten my component values nailed down and working on the final layout. Here's a pic:
Here's a high-res version:
http://picasaweb.google.com/eisenbarth.ma/Crossovers
Tweeter input starts on bottom left, through cap to the inductor on the far left to ground (2nd order) then a resistor dividing network. Output is taken between two resistors on bottom.
Woofer coil starts on bottom right, then a RCL to ground.
Pretty simple.
Any comments? Can I get away with moving things closer together?
Thanks!!
Old 4th February 2009, 02:36 AM   #2
HK26147 is offline HK26147  United States
If you make sure that the inductors are NOT oriented in the same axis ( ie x,y,z ) you minimize magnetic induction and can then move them much closer.
Old 4th February 2009, 02:38 AM   #3
luvdunhill's Avatar
I've always kept them 6" apart and ensure that if you look through the hole of one inductor you cannot see another inductor. Always has served me well
Old 4th February 2009, 02:49 AM   #4
R-Carpenter's Avatar
Send a message via ICQ to R-Carpenter
Man, this topic reminds me of a young girl showing of her behind and asking if the skirt is too short.
Nice tidy job. Fancy coils and resistors. Whats in front of it?
Old 4th February 2009, 02:49 AM   #5
I don't know if you have read AudioXpress 5/01 ( Inductor Coupling ) Dennis Colin:
He outlines a variety of orientation options and coupling results.
Very good article - there was a earlier one that showed the effects of crosstalk on an oscilloscope.
Standard practice is 90 degree orientation and as far apart otherwise
Old 4th February 2009, 03:35 AM   #6
luvdunhill's Avatar
no, but sounds very interesting. I think I can reduce the size a bit.. if I could move the middle inductor down one hole and to the left one position in the grid. Like I said, I usually have things very spread out and haven't tried to really optimize things
Old 4th February 2009, 03:52 AM   #7
Unfortunately I don't have a good link that covers "mutual inductance"
But I'm sure you have seen illustrations of the magnetic flux lines that expand out from the coil torus - the pole orientation is a line down the center of the hole.
The Big foil air core ( on the far right ) shares the same orientation as foil inductor on the far left.
Turn the Big one 90 degree so it's "hole" axis is oriented right to left.
Then all 3 coil are on different axis and can be closer.
( Not to be boring but mutual inductance is the principle behind transformer action )
Old 4th February 2009, 03:58 AM   #8
luvdunhill's Avatar
ah. Google helps us here:
http://www.audioholics.com/education...osstalk-basics
Old 4th February 2009, 04:00 AM   #9
You got it!
The article I mentioned "tweaks" upon this.
Good luck
Old 4th February 2009, 04:45 AM   #10
Moondog55's Avatar
Another very good link to this subject
http://www.troelsgravesen.dk/coils.htm
I have actually printed this out and have it above my work bench as an "Aide Memoir"
Ted
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Circuit and PCB Layout comments dsavitsk Tubes / Valves 18 4th May 2006 11:56 PM
Comments on my Aleph-X layout? Kari Pass Labs 165 16th August 2005 08:51 AM
Need comments on this P3A PCB layout goering Solid State 7 27th August 2004 06:04 AM
Page generated in 0.11375 seconds (79.50% PHP - 20.50% MySQL) with 10 queries
