real RMS power
real RMS power
Old 15th April 2003, 11:47 AM   #1
Dj BASS AMP is offline Dj BASS AMP
Account Disabled
Question real RMS power
how much real RMS the LANZAR MXW15 - 1200W MAX can work Max ?? (4 ohm)
LINK
Old 15th April 2003, 04:59 PM   #2
OMNIFEX is offline OMNIFEX  Jamaica
OMNIFEX's Avatar
I would say half of the maximum power. But, not sure
do to the limited information on the site.
OMNIFEX
Old 15th April 2003, 08:24 PM   #3
ChesterFuzzin' is offline ChesterFuzzin'
Default here's the REAL rms formula...
for such lame claims..
just take whatever the max they say and divide by 4..
and that's your true RMS..
there's my 2 cents..
so basically..
its a 300 watts rms sub...
Old 15th April 2003, 09:18 PM   #4
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Now now now people, you're all forgetting.
The "RMS" cancels in the equations when you go to power. Power is inherently RMS.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 15th April 2003, 09:22 PM   #5
Account Disabled
in all the type os spek' i divide by 4 ?? to get true RMS ...
Old 15th April 2003, 09:47 PM   #6
OMNIFEX's Avatar
You can't divide the maximum by four, until you know
how the maximum was measured.
Maximum doesn't necessarily mean peak.
Dj BASS AMP,
your best bet is to contact the manufacter.
Best Regards,
OMNIFEX
Old 16th April 2003, 12:20 AM   #7
SkinnyBoy is offline SkinnyBoy  Australia
Banned
Send a message via MSN to SkinnyBoy
I hate the way they rate speakers... for instance.. Peerless say "Long term Max System Power" is that maximum? or RMS? Its max, lol, but its continuous.. :S AHHH!!!! lol
Old 16th April 2003, 10:31 PM   #8
haldor is offline haldor  United States
There is often more than one power rating on a speaker in an attempt to reflect different real world issues that can limit how much power the speaker can handle.
Peak Power. This is typically the physical excursion limits of the suspension and cone. Exceed this and the speaker tears itself apart. Drive with this much power for very long and the voice coil will fry.
Continuous power. This is the amount of power that the voice coil can withstand long term without the voice coil overheating. This rating is often called "RMS" power, which is not really that big a misnomer since the limiting factor is the amount of heat the voice coil can dissapate.
Music Power. This can be a garbage spec, but there is some logic behind it. The idea is that music typically has a low crest factor (the average power level is usually considerably lower than the dynamic peaks). In between peaks the voice coil gets a chance to cool off. The kind of music you are playing determines if this spec means anything. If you listen to heavily compressed music then the average power will much closer to peak power.
Now some companies like to lie with specs. "Peak" power might simply be the peak voltage (VAC RMS * sqrt 2) times peak current (IAC RMS * sqrt 2). This is simply a way to double the power rating and have a tissue of credibility if called on it.
Example of lying Peak Power rating: 100 W into an 8 Ohm load:
VAC = 28.3 RMS. Peak V = 40V
IAC = 3.5A RMS. Peak I = 5 A
40V * 5A = 200 Watts Peak.
This kind of calculation has nothing to do with the peak power rating I described above.
Phil
Old 17th April 2003, 12:35 AM   #9
theChris is offline theChris
BTW, ask lanzar for the specs on that sub... the sent me the specs with Qts and Qes reversed i think (hope). Qts was somehow larger.
if only it could be used for good, not evil...
real RMS powerHide this!Advertise here!
Real music power Conta Tubes / Valves 16 14th February 2008 04:19 PM
Real power of zapco z600c2 Clipped Car Audio 5 13th September 2007 05:40 AM
About the real power of an amplifier. dex13 Car Audio 4 17th August 2007 12:23 PM
Real brute power amplifier ostie01 Solid State 9 1st August 2006 08:53 AM
