Snell A3i Woofer Replacement - Help Needed
Old 3rd February 2009, 12:02 AM   #1
tgroendahl is offline tgroendahl
Default Snell A3i Woofer Replacement - Help Needed
What was supposed to have been a replacement of the foam surrounds, turned out to be a serious repair of the right woofer.
So now a replacement of both woofers seems to be a better idea.
Has anyone tried this with succes?
We have found the T/S parameters of the RCF L12P48 12" driver at: http://www.thielesmall.com/database.asp#
Fs = 19.5 Hz
Qes = 0.45
Qms = 10
Qts = 0.43
Vas = 270 L
Re = 5 Ohm
Thanks in advance for any reply!
Thomas
Copenhagen
Old 3rd February 2009, 02:58 AM   #2
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
If those specs are fore real I doubt you will find any though, SBAcoustic 12" is pretty close
A repair could seem like the best way, but I doubt it will maintain those specs after repair...could end up being way off
sometimes we know very little, and sometimes we know too much
Old 16th March 2009, 08:05 PM   #3
Hanny65 is offline Hanny65  Italy
Do you still have the woofers? In which conditions they are?
Old 20th March 2009, 04:27 PM   #4
The RCF woofers are in a pair of Snell A3i, belonging to an audio-acquaint here in Copenhagen, who had a problem with one of them. He send the L12P48 unit to repair, and I havenĀ“t spoken to him since, so I guess his Snell's are working again.
Snell A3i Woofer Replacement - Help NeededHide this!Advertise here!
FS: Snell 6.5" - 7" mid-bass driver woofer feke67 Swap Meet 0 31st December 2007 08:11 PM
Woofer replacement glen65 Multi-Way 0 28th October 2007 04:18 AM
Peter Snell, Snell model A forr Multi-Way 1 25th May 2005 12:46 PM
Snell eIII new woofers needed lt_texan Multi-Way 1 14th May 2005 06:47 PM
Snell replacement 10 inch woofer hollytone22 Multi-Way 5 26th March 2005 07:13 AM
Copyright ©1999-2017 diyAudio
