In order to have a slim cabinet for a line array, I want to mount the tweeter in front of the woofer. Crossover frequency is about 3.1Khz
1) Is it possible to compensate for the acoustic center offset of about 45 mm 'ween woofer/tweeter with an all pass filter (its gonna be an active setup)? 2)Given that the woofer is about 4" and the tweeters are a little over an inch (dayton neos, after cutting the flanges). What is the effect of the tweeter blocking part of the cone? Is it audible to a reasonalby good ear? Thanks in advance, Goldy
Audio enthusiast/hobbyist |
#2 |
it's possible,
but then the sound has to get around the tweeter some how. at 3khz, that's not easy to do.
Just because you can't hear it doesn't mean no one can. |
#3 |
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency |
#4 |
See also:
http://www.hammerdynamics.com/ |
#5 |
Dilletante, tinkerer and beggathoner supreme
Doesn't a Neo tweeter make this approach easy physically, cross-over I'm not qualified to comment on, but so much neater than others I've seen
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#6 |
"If we knew what it was we were doing, it would not be called research, would it?" A. Einstein |
| WTB: Top Mount Tweeter | warnsey | Swap Meet | 0 | 27th May 2008 10:20 PM |
| 2 way, front ported, stand mount, HELP | nordhaven | Multi-Way | 4 | 8th March 2008 01:33 PM |
| Morel 8in Woofer (MW265) and Top Mount Tweeter (MDT41) | mmgando | Swap Meet | 2 | 13th December 2007 04:16 PM |
| suspending a small tweeter in front of woofer for "coaxial" effect? | bikehorn | Multi-Way | 3 | 2nd January 2006 02:04 PM |
| How to mount the Fountek JP-2.0 5" tweeter? | mazeroth | Multi-Way | 2 | 18th January 2005 03:03 AM |
