Old 2nd February 2009, 12:09 PM   #1
Default Measuring tools
I`m in the need of some tools.
One microphone and one signal acquiring board.
The Behringer ECM8000 and M-Audio Transit is a good combo ?
Old 2nd February 2009, 05:19 PM   #2
Ron E is offline Ron E  United States
Ron E's Avatar
That should work, but the Behringer needs phantom power. The simplest phantom power preamp is by a company called Rolls, but you might be able to find the Xenyx UB-802 mixer for cheaper. Either will work. You could also buy an M-Audio or EMU-0404 external sound interface with built in phantom power.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 2nd February 2009, 07:09 PM   #3
I have used the MXL mic mate with success with the behringer mic
http://www.sweetwater.com/store/detail/MicMate
Others have used this solution
M-Audio MobilePre USB
http://www.m-audio.com/products/en_us/MobilePreUSB.html
Old 6th February 2009, 03:30 PM   #4
The MXL Mic mate seems a good option.
ECM8000 vs Apex APEX220 ?
Old 6th February 2009, 05:04 PM   #5
Ron E's Avatar
http://www.amazon.com/Rolls-MP13-Min.../dp/B0002BG2QI
http://pro-audio.musiciansfriend.com...802?sku=631263
The Apex doesn't look any better than the Behringer.
I have heard there is a mic from a company called Naiant that is very good. http://www.naiant.com/xmspecification.html
Old 6th February 2009, 05:36 PM   #6
I would suggest going over to homerecording.com message board and asking them about some of the brands that have been mentioned here. Particularly about preamps. What you are looking for is something transparent. I would suggest a M-Audio DMP pre as a low budget transparent pre. The Behringer ECM8000 is a good as any, shy of spending many times more. I would also recommend a M-Audio 2496 sound card. Recently discontinued, these can be had cheap. They where in production for years and are tried, tested, and proven.
Old 6th February 2009, 05:46 PM   #7
Well for the measurement task I use a notebook, so no Audiophile2496 in this case.
One thing that APEX attracts me is the lower noise floor.
Old 6th February 2009, 06:38 PM   #8
Before you get very carries away, check your onboard sound. It probably isn't up to it. Test it using this software. If it goes 100-15k without more than 3db variation, I would be surprised. For testing, all you need is a 1/8" TRS patch cable. Onboard sound is notoriously bad. Be it a laptop or a PC. For listening to music, I use a SB X-Fi card. The SB cards have gotten MUCH better since E-Mu bought them. The specs I get from this card using the testing software mentioned above is 20 Hz to 20 kHz, -0.68, +0.02 dB. The point is, I would test the onboard sound before I would spend the $$ on mics and pres and see what you have to work with. Like you and a few others mentioned, USB in would be better. Again, I would check over at Homerecording.com Message board for good, transparent USB pres. Specs rarely tell the whole story.
BTW, what are you using to feed a test signal to the drivers?
Old 6th February 2009, 06:46 PM   #9
Yes I know.
Just for getting used with the program.
I must get an external soundcard for real measurements.
Old 7th February 2009, 03:10 AM   #10
Ron E's Avatar
http://newsgroups.derkeiler.com/Arch.../msg01504.html
..whatever you say.... looks pretty much the same to me. If you like black better than silver, go for it.
I have onboard sound in a IBM PIII laptop that works great, and any halfway decent onboard AC97 codec should work OK, as well, and it won't be +/- 3dB either... An onboard ac97 (soundmax?) that I have is better than a SBcard I used to try to use...
DIY Tools Alai Equipment & Tools 7 1st April 2009 03:30 AM
Necessary tools for diy? wixy Multi-Way 133 28th February 2007 05:34 PM
tools? tomtt Equipment & Tools 1 18th October 2006 02:35 AM
New tools edjosh23 Everything Else 25 21st July 2006 08:20 AM
Page generated in 0.10982 seconds (79.38% PHP - 20.62% MySQL) with 11 queries
