Which of these two kits looks more promising? Which of these two kits looks more promising? - diyAudio
Old 31st January 2009, 06:24 PM   #1
lurer is offline lurer  Norway
Default Which of these two kits looks more promising?
Hi!
I havent yet built a kit, but im in a planingphase.
From a kit i want several things:
- Fast and reasonably dry bass. Must be very accurate.
- Bass reaching atleast down in the 20-30hz region.
- Total membrane area of the drivers should be 10" or more per speaker.
- Price: 1000 or excluding woodmaterial
- Must be easy to follow the manual when building it.
- Generally they must provide very good quality sound.
- Sensitivity at 90-91db or higher
This is the kits i have been looking at:
1.
http://www.troelsgravesen.dk/JA8008_DTQWT.htm
This is a danish contruction which to me looks quite promising. Troels Gravesen has got a good name in Norway and i belive it when he says its his best project. If you look at the construction, it is a little bit different from the normal speakers. Dont know if thats good or bad.
2.
http://www.iplacoustics.co.uk/S5%20Kevlar%20Ribbon.htm
This is UK based, and a transmissionline construction. I got TL-speakers myself and i am weak for type.
Basically the IPL speakers are almost half the price of the first kit. Both are based outside Norway and i would need to import parts at a quite high cost. This also means i havent heard any of them, so i might end up with speakers that wont fit 100%, but ill be changing poweramp and maybe Pre-amp also.
Im planing on using a valveamp from 35watts and up on the speakers.
Do you got any comments on any of these kits? Does something strike you as potentially good or bad? Personal experiences etc..
Any other kits that fits my criteria are welcome
Thanks!
Espen
Which of these two kits looks more promising?Hide this!Advertise here!
Looks like a promising SE build ?? bereanbill Tubes / Valves 10 22nd May 2009 04:49 PM
Where to buy kits Or best SS kits Kitarist Solid State 1 8th February 2009 12:03 AM
USB to XLR kits? tommas Digital Source 2 4th August 2007 01:45 AM
DAC Kits gilid Digital Source 17 1st September 2002 07:00 AM
Copyright ©1999-2017 diyAudio
