I'm considering reconfiguring these as I'm kinda stuck with them for now. I'm thinking of moving the horn outside the box in a box extension on the side to allow the woofer horn more air.
The ports will be closed (or moved to the extension) and the chamber area smaller. They'll be running with tapped horns. I'd rather kill the port completly to eliminate some phase issues coupling with the subs. My other option is to extend the back of the cabinet, adding the small chamber and a 20 cm throat to couple to the existing lf horn and wrapping around the HF driver. The remaining area around the hf driver is about what a sim I did shows to increase the woofers upper range utilizing the existing cabinet. I.E. retrofit kit. Thoughts? ![]() Moving the horn outside would require configuring left/right sets of boxes but that's ok if it makes a big difference. Kind of like a horn loaded version of the versarray. Figured I'd ask before beating my head into a wall again They're actually great convienient little boxes, but if I can improve them a little that would be nice. I have 12 total. Load is Kappa12a (xover at 115) and PV22xt (xover at 1.2k). |
| car smps reconfiguration | PM650 | Power Supplies | 0 | 10th August 2007 07:36 AM |
| newbie with input tran. question and wiring question | imo | Solid State | 0 | 18th January 2006 10:10 PM |
| Acoustat reconfiguration | The Peasant | Planars & Exotics | 15 | 10th June 2004 07:49 PM |
| old speaker question, bullet midrange question & link to speaker project | wallijonn | Multi-Way | 10 | 5th November 2002 06:03 AM |
| Page generated in 0.05116 seconds (75.85% PHP - 24.15% MySQL) with 10 queries |
