I was thinking on getting the Sound Easy program version 15, as I have the X-over 3 Pro along with the WT3 and True RTA. I am not familiar with the Sound Easy program, but have some knowledge on the programs mentioned. I know that programs like CLIO, LEAP, etc are very accurate, but are on the expensive side. Any suggestions would be appreciated!
Thanks! |
#2 |
If you get SoundEasy, get the how-to book. It's an excellent piece of software, but you need the book.
DIYaudio for President ! |
#3 |
Hi simon5, Thanks for that info! Where can I find the how-to- book? Also, Do you have the Soundeasy speaker design program?
Thanks, Emile |
#4 |
You can get the book here :
http://www.musicanddesign.com/Guide.html It's even recommended by the SoundEasy crew. I don't have that program, but I plan on purchasing it in a not too distant future. In my opinion, it's the only complete and affordable design solution.
#5 | |
Join the SoundEasy Userslist, and ask lots of questions. Yes, SoundEasy is low cost. It is also under continual development, so you may end up doing an unlimited series of upgrades if you are interested in the new features. V15 has mostly user-requested features; much of the user interface has been revamped since its inception. I use SoundEasy. Buy it if you need its extensive functionality. Use SpeakerWorkshop if you don't.
Shaun Onverwacht |||||||||| DON'T PANIC |||||||||| |
#6 |
One of the interesting features about the soundeasy program is it's capability to use it's built-in x-over/s on speakers to get a better idea of what they will sound like before actually assembling the components.
Does the Speaker Workshop have this feature? Also, how would these programs compare to X-over 3 Pro from Harris Technologies? Thanks, Emile |
#7 | |
Xover pro is junk, IMO. Unless things have changed it cannot even use measured phase, which is pretty important.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#8 | |
Thanks |
#9 | |||
SE offers many other features in addition to these (read the SoundEasy product page for full details). Quote:
HTH
#10 |
To add to what Shaun said, Speaker workshop is worthless because it doesn't let you use imported phase. Even Speaker workshop or Passive Crossover Designer let you use measured impedance frequency response and phase and they are free.
The soundeasy design guide is not a book, but on CD. It is very good. If you are only doing spl measurements in SoundEasy, and not t/s parameter testing you don't need to use any jig or circuit. If you did want to provide some additional protection for your soundcard when doing frequency response measurements, you could solder a resistor onto your reference probe input but that is optional. Youi will need a mic and preamp to do the measurements (same with any of the packages) Short of LEAP, the only design package I would consider other than Soundeasy is LspCad Standard and it is not as full featured as SoundEasy. To get similar functionality you would need to get LspCad Pro which is more than double the price. Good luck, Dennis |
| New open source loudspeaker design program project started | Karoliina | Multi-Way | 33 | 10th December 2009 10:18 AM |
| Horn Design Program | jhelm_waterw | Multi-Way | 1 | 13th March 2007 03:39 PM |
| Newbie need loudspeaker design advice | rockstilo | Multi-Way | 1 | 4th March 2005 01:42 PM |
| Page generated in 0.11300 seconds (83.09% PHP - 16.91% MySQL) with 10 queries |
