Need advice on a loudspeaker design program - Page 3 - diyAudio
Old 2nd February 2009, 06:25 AM   #21
Shaun is offline Shaun  South Africa
Shaun's Avatar
Originally posted by FSHZ:42
Wanting to know if I would have to build some type of jig to go along with the SE for measuring speaker parameters or could I just use my WT3?
You don't need a jig with SE. But I find a switch box helps to tidy things up.
Mine has the following:
1) Voltage dividers to reduce signal to line level (for the sound card)
2) Toggle function between acoustic measurement and impedance (for Z, R, C, L and T/S).
3) A switchable series capacitor for protecting tweeters
4) The sense resistor is external to the jig (unlike Wallin, as SW measures differently) for best accuracy.
5) The switch box also has connectors for connecting the soundcard inputs (RCA), amplifier output and test leads.
Whether you need a jig is down to your personal preference.
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 2nd February 2009, 08:20 AM   #22
FSHZ42 is offline FSHZ42  United States
FSHZ42's Avatar
O.K. First I need to order the SE program. While I am waiting on it to arrive, I will get the $10.95 SE guide. I would guess that this guide is for proper set-up for the program. Can you tell me if this would be the right approach to this set-up, and also what other tools or equipment do I need. I am presently using x-over 3 pro, which I feel is not that good. I have the WT3, True RTA 1/3 octave, a digital decibel meter (rat-shack) in which I was told to use for measuring the drivers. Let me know what you think! Oh, one last thing, my sound card is Sound Blaster Audigy 2ZS, will SE work well with it?
Thanks,
Emile
Old 2nd February 2009, 08:40 AM   #23
Shaun's Avatar
Have you read the SE product page? SoundEasy .
There you'll find the original manual and some very useful articles. Also, there's a short list of known compatible sound cards. Else post on the SE Userslist & ask if anyone else is using the card you intend to use. Most cards work for the basic measurement functions. But as for the advanced DSP functions, e.g., digital filter, you have to get a card that uses WDM (I think) drivers.
And for the measurement you'll need a mic that does not apply any processing to the measured signal, and that has a pass-through signal for the sound card to receive. Best also to get the mic calibrated, but usually you can find a generic calibration file for your mic that also tends to be sufficient. Also, use a mic that does not have a bulky body that produces diffraction (some mics are "aerodynamic" in design, and this reduces diffraction). You'll also need an amplifier (old receiver will work fine).
Shaun Onverwacht
Old 2nd February 2009, 09:11 AM   #24
FSHZ42's Avatar
Well I already purchased the SE guide, so I guess they will mail it to me. As far as the mic is concerned, could you take a look here:
http://www.parts-express.com/wizards...TOKEN=56397982 and let me know which mic/s would be a good choice. I also have an Accurus intergrated amplifier, and was wondering if I could use it to do the measurements?
Thanks Again,
Emile
Old 2nd February 2009, 09:27 AM   #25
Shaun's Avatar
The Behringer ECM800 is a popular tool. But it requires a preamp with phantom power. Some sound cards have a compatible preamp built in. Again, ask at the SoundEasy userslist for guidance here.
Most receivers/integrated amplifiers should work. You basically need a low impedance source for impedance and acoustic measurements. Those that have a bridge output are not suitable.
Shaun Onverwacht
Old 2nd February 2009, 09:53 AM   #26
FSHZ42's Avatar
Shaun, could You send me a P.M. where I may contact you direct?
Thanks,
Emile
New open source loudspeaker design program project started Karoliina Multi-Way 33 10th December 2009 10:18 AM
Horn Design Program jhelm_waterw Multi-Way 1 13th March 2007 03:39 PM
Newbie need loudspeaker design advice rockstilo Multi-Way 1 4th March 2005 01:42 PM
Copyright 1999-2017 diyAudio
