Need advice on a loudspeaker design program - Page 2 - diyAudio
Old 1st February 2009, 03:26 PM   #11
Ron E is online now Ron E  United States
Ron E's Avatar
Originally posted by djarchow
To add to what Shaun said, Speaker workshop is worthless because it doesn't let you use imported phase. Even Speaker workshop or Passive Crossover Designer let you use measured impedance frequency response and phase and they are free.
I think you meant: "To add to what Ron E said, XOver Pro is worthless because it doesn't let you use imported phase."
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 1st February 2009, 03:49 PM   #12
MJL21193's Avatar
Originally posted by FSHZ:42
I know that Chris from Solen Electronics in Canada uses the X-over 3 Pro for doing cross-over designs for his company, so it cant be that bad of a program.
Have you looked at some of their crossovers?
I don't know about Sound Easy, but Speaker Workshop has a pretty steep learning curve and requires a lot of setup to have it running right. It's free and is very functional when you get the hang of it.
The jig is a bit of a stumbling block, as is the mic preamp and measurement mic but I don't think Sound Easy comes with one either (am I wrong?).
I built an all-in-one jig that has an adaptation of the Wallin jig, a battery powered mic preamp and an LM3886 based power amp (low power). It is a convenient package and makes the process less of an ordeal.
Old 1st February 2009, 06:01 PM   #13
Yes I did. I really messed that one up. Thanks for catching that.
Regarding the Wallin jig for speaker workshop, I never saw the need for that. If you choose to do impedance meausrements with SoundEasy (or SpeakerWorkshop) a simple voltage divider can be put right inline with your cable. In any case the poster has the wooferr tester so I would assume he would be using that for t/s measurements.
SoundEasy, just like LspCad, Leap, Praxis, Clio etc is an engineering tool. To get the most out of it, you need to understand what you are doing when designing a speaker.
Dennis
Old 1st February 2009, 08:09 PM   #14
Ron E's Avatar
That is pretty cool John!
My Jig is just a little plastic box with a voltage divider and two switches. It works but it is a bit of a pain and I always thought about adding a small amp, but never did so.
I agree that these programs can have a steep learning curve. Getting one's feet wet with something like Speaker Workshop can help someone decide whether they want to spend the money on something a little more user friendly.
Old 1st February 2009, 08:13 PM   #15
FSHZ42 is offline FSHZ42  United States
FSHZ42's Avatar
Dennis
Wanting to know if I would have to build some type of jig to go along with the SE for measuring speaker parameters or could I just use my WT3? Also, where is the best place to order it?
Emile
Old 1st February 2009, 08:33 PM   #16
FSHZ42's Avatar
[QUOTE]Originally posted by MJL21193
[B]
Yes I have, and would have to agree that they are quickly calculated using x-over 3 pro with bass box program all from harris technologies! I do have quite a few drivers that I would like to design a good set up for them. One set of drivers in particuliar are the Dynaudio D-260 tweeters and the D-76AF midranges. There are other drivers as well that need better design work than what x-over 3 pro can offer. I would guess that I will have to order the SE program and begin a new journey!
Emile
Old 1st February 2009, 08:49 PM   #17
[QUOTE]Originally posted by FSHZ:42
[B]
Emile
You can use your WT3 to do all your impedance ant t/s measurements. As for making a jig for SE, you can get by with a simple cable with aligator clips on the ends and a single resistor in series with one of the clips. John K's users guide spells this all out.
Dennis
Old 1st February 2009, 09:43 PM   #18
FSHZ42's Avatar
Dennis
Where can I get John K's user guide? Also will this guide help me to set the program up?
Old 1st February 2009, 10:50 PM   #19
http://www.musicanddesign.com/Guide.html
It will take you all the way from setting preferences in the software, though making probe cables, taking measurements, designing the XO etc. Well worth the $10.95.
Dennis
Old 1st February 2009, 11:38 PM   #20
FSHZ42's Avatar
Dennis
Thanks Dennis! Just wondering if I could contact you via phone?
If so, please PM me.
Thanks,
Emile
New open source loudspeaker design program project started Karoliina Multi-Way 33 10th December 2009 10:18 AM
Horn Design Program jhelm_waterw Multi-Way 1 13th March 2007 03:39 PM
Newbie need loudspeaker design advice rockstilo Multi-Way 1 4th March 2005 01:42 PM
Copyright 1999-2017 diyAudio
