In a tri-amp 4-way situation with powered subwoofers (not controlled by the Ashly), can the Ashly XR-2001 set the low and high x-over on the next lowest driver?
Do you just rely on the box tuning for the low end of the woofer and just set the top end x-over of the woofer? I can see where the mid would take over where the woofer was crossed at the top, likewise with the mid to tweeter, but I'm not sure about setting basically a bandpass for the woofer. Maybe tweak the sub x-over, or maybe it's just not that critical with the correct woofer box tuning? Assuming of course that both the sub will operate up to the low end of the woofer and the woofer will likewise operate as low as the top end of the sub. It's just that the mid has basically a bandpass set up. The sub will only go so low, and the tweeter so high, but the woofer appears to rely on nothing but tuning for what will be the lower end of its bandpass. Hope this makes some sense, or that it's a no-brainer and I'm over analyzing the whole deal. Thanks. |
| Hot Rodding an Ashly X-Over | docaudio | Chip Amps | 3 | 8th May 2011 08:09 AM |
| phono pre RIAA 2001 | oldeurope | Tubes / Valves | 5 | 8th May 2008 09:05 AM |
| The TAD TD-2001 Thread | ark | Multi-Way | 1 | 14th July 2007 04:17 PM |
| JE LAB's 2001 2A3 & Preamp??? | wwflyball | Tubes / Valves | 18 | 4th March 2006 12:49 AM |
| P-CAD 2001 - image posting? | marjan | Everything Else | 2 | 17th March 2004 12:25 PM |
| Page generated in 0.05869 seconds (68.19% PHP - 31.81% MySQL) with 10 queries |
