Hi guys,
I am after some 2-way speakers for mixing and producing music on. Being a university student, I have little money. However, I do more time than I know what to do with. These seem like good conditions for DIY! I am handy enough to follow a plan, but I'm not even going to think about trying to design or tweak them myself. Requirements:
I would prefer to buy the amp off-the-shelf, unless there is a very easy (but good) design I can follow. I definitely do not want a poor quality amp and I would like to avoid buying second hand. Questions:
Thanks! |
#2 |
I don't know if the Onkyo M-282 is available to you, but it's about $200 U.S. and is impressive in it's output and SQ. I use one to power a set of Zaph SR71 and i spent about $700 U.S. including cabinet materials. Don't know if you can surpass the performance with active monitors, but it's a start.
#3 |
http://www.theloudspeakerkit.com/sho...&ProcessType=1
These are apparently quite decent. However, I am somewhat reluctant to pay $400AU, when the woofers cost $20US and the tweeters cost $16US. I could probably get the full set of woofers and tweeters for about $150AU, posted. Surely wood and XO wouldn't cost $250?
#4 | |
This amp has only RCA in, from what I can see. I would like balanced TRS/XLR. I think this will limit me to amps like the Alesis RA line and similar. Also, the Zaph SR71 is rear ported. |
#5 |
Price the drivers and XO parts at www.speakerbits.com before you make up your mind, remember that there is no surface mail from the USA anymore and airmail rates are a KILLER.
Some very fine designs can't be made here as drivers are not available here or discontinued. Look up Darcher Audio. It can be done but will take time to find a design using drivers available in OZ Balanced inputs are nice but really not needed, I detect no difference between my Alesis RA-100 and the new model, SQ noise or volume
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#6 | |
Maybe I'm best off just getting a kit from LSK or buying off the shelf? Do you think the LSK kits provide good value? |
#7 |
They represent value if your skills/time is limited.
Look up the pro-audio sites and see what is being used and then note the prices, add a zero to your budget if buying off the shelf. Most pro gear these days is active, Bi-amped and driven from the mixer output
#8 |
So, bottom line, how would LSK M5s compare to something like KRK RP6s? They will work out to be roughly the same price.
I don't really see how LSK can provide a speaker which is on par with "commercial offerings that cost 2 to 3 times as much". The value proposition of DIY is that you cut out all the overheads. The only overhead LSK cut out is assembly, but they have the additional overhead of making the kits easy to assemble (eg. cutting the tongue and groove in the wood). Obviously they don't have the buying power of KRK, so one would think the benefits are almost entirely eroded? Furthermore, everything I have read says that bi-amplified speakers are greatly superior to these passive types. Can anyone clear some of this up for me? I don't really get it! |
#9 |
CallingAugerpro (Brandon) Powered Noobster MTM?
In your situation i would think any decent small system would do, I can't comment on available speakers I haven't bought off the shelf in 12 years ( which is how old my HT system is ) but most of what I build is bi-amped 3-ways, and take ages to get "Right"
#10 |
http://www.parts-express.com/pe/psho...74&ctab=5#Tabs
If you could get suitable drivers for this little amp I'd be tempted to import a couple, about $350 landed I think
| CDPRO2 Group Project (open source project) | BrianGT | Digital Source | 147 | 8th August 2008 11:37 AM |
| My OLD Project....... cheap tube audio project!!! | tube-lover | Tubes / Valves | 4 | 8th May 2008 09:26 PM |
| first project | ceebmoj | Full Range | 5 | 23rd January 2008 07:51 AM |
| My first project, cool project. | sorinsistem | Solid State | 3 | 19th January 2006 05:08 PM |
| Page generated in 0.10595 seconds (82.05% PHP - 17.95% MySQL) with 10 queries |
