Old 27th January 2009, 06:27 PM   #1
Tyimo is offline Tyimo  Hungary
Default Primary Drive Loudspeaker by Tim de Paravicini
Hi!
Does somebody knows this:
http://www.ear-usa.com/new_products.htm
What is this loudspeaker?
How is it working?
Tyimo
Old 27th January 2009, 06:40 PM   #2
http://www.stereophile.com/interview...av/index2.html
Scroll to the bottom of the page...
Old 27th January 2009, 06:44 PM   #3
Yes, I know it.
.."Basically, it's a dynamic speaker system, with a tweeter and a midrange and a bass unit. The bass unit and the midrange drive a membrane. The bass unit makes a membrane of effectively 12" by 18" (305mm by 457mm) surface area bend and vibrate to put bass into the room. So it has dipole properties. I don't make the drive-units myself and I subcontract the cabinets, but it's still my basic principles."
But I don't understand this sentence:
...The bass unit and the midrange drive a membrane. The bass unit makes a membrane of effectively 12" by 18" (305mm by 457mm) surface area bend and vibrate to put bass into the room...
Maybe a drawing or a picture would help me to imagine how it works....
Tyimo
Old 28th January 2009, 01:24 PM   #4
Is this something like a normal dynamic driver's voice coil mooves a big and flat surface (membrane)?
Tyimo
Old 28th January 2009, 03:11 PM   #5
ashok's Avatar
Default Grown up computer speakers ?
I seem to recall that I saw someone put up pictures of something like this a few years ago. Was it on diyaudio .com ?
It was supposed to be a computer speaker. Basically it consisted of two vertical posts spread a few inches apart with a pvc (?) film stretched between the posts ( both sides). The driver was at the bottom and coupled with the air between the two membranes through a small hole at the bottom.
Rather simply made at that time. Supposed to sound very interesting. It was a dipole of course because it radiated from both sides . Did he get a patent for it at the time ?
There were pictures also with a brief description on how to make it.
AM
Old 28th January 2009, 03:34 PM   #6
Would be nice to see it.....
Tyimo
Old 28th January 2009, 03:44 PM   #7
ashok's Avatar
Here you go !
I saw a different web page but at first sight the speaker looks the same !
http://www.audiojunkies.com/blog/495...lanar-speakers
This was posted in 2007 . What I saw initially was much older !
AM
Old 28th January 2009, 05:38 PM   #8
Thanks Ashok!
Now I understand. Do you think that the Paravicini speaker working in the same way?
Tyimo
Old 28th January 2009, 05:46 PM   #9
Looks like the NeXT best thing.
Old 28th January 2009, 05:54 PM   #10
frugal-phile(tm)
planet10's Avatar
They could be a derivative of the podium speakers, or a development of the speaker developed by the company Moray James worked for in Calgary. AFAIK one of the prime guys headed to the UK.
Moray would be able to tell us more.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
transconductance power amplifier for current-drive loudspeaker? alex0 Solid State 30 26th May 2008 08:15 AM
FS: Hitachi Router and Terk outdoor HD antenna, BD-Rom drive, Xbox HD Drive and more. Dougie085 Swap Meet 0 3rd May 2008 07:31 PM
Asymmetric drive to asymmetric loudspeaker tolits Multi-Way 5 11th January 2008 05:14 PM
Idler wheel drive vs. Belt-drive mig-ru Analogue Source 4 3rd December 2003 12:06 AM
Computer Question-Any Problems Transferring Office 97 From D Drive to C Drive kelticwizard Everything Else 12 22nd January 2003 03:34 AM
Page generated in 0.11256 seconds (77.47% PHP - 22.53% MySQL) with 11 queries
