http://www.flickr.com/photos/33622597@N05/3230215048/
At least the inductors are all perpendicular to each other. Is there anything to correct?
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#2 |
Even though the toroids are perpendicular, you still want as much distance between them as you can get. A common mistake is to make a filter PCB or board where the filter is placed on when it's actually better to have it spread out all over the backpanel.
#3 |
Your layout is good. The short distance between the steel core and the air core in the middle is perfectly fine since they are orthogonal. I measured a case where two of them are nearly touching each other. It was still okay.
I would move the top one to the right side of the middle one. -jAy |
#4 | |
Right Or you could say its ok to have some distance between woofer section and tweeter section Saturnus may think of when people cramp it all together tightly to make all components reach each other to avoid additional wire...something one should not do Theres no harm done in using a bit of solid core wire I believe I can hear that it sounds better when each section have each their own dedicated ground wire from speaker terminals |
| Eagle vs. Sprint-Layout for PCB design/layout | hollowman | Parts | 9 | 9th July 2011 04:34 AM |
| Crossover Layout Comments | luvdunhill | Multi-Way | 13 | 4th February 2009 02:50 PM |
| Crossover Layout OK? | samtny | Multi-Way | 10 | 1st December 2007 02:02 AM |
| Crossover Layout Tips | bikedude | Multi-Way | 3 | 29th July 2006 10:36 PM |
| Need Crossover layout for JBL Ti10K | Jan De Smet | Multi-Way | 1 | 1st February 2004 08:05 PM |
| Page generated in 0.07616 seconds (75.09% PHP - 24.91% MySQL) with 10 queries |
