What beats the R2904/7000 ring radiator?
Old 11th August 2011, 07:50 PM   #121
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
A horn + HF driver
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 11th August 2011, 08:44 PM   #122
megasat16 is offline megasat16  United States
Thanks but I don't need horn. I am horny enough.
Old 11th August 2011, 10:13 PM   #123
Originally Posted by megasat16 View Post
Bump!
Very interesting thread. I actually read from 1st to the very last post made above me.
But there was no conclusion to what is a better tweeter.
Since this thread is over 2 years old with no information update, I wonder anyone has actually owned, build, listened and measured the three tweeters below.
I like to hear someone's opinion both subjective and objectively for the tweeters below and how they stack up in the HD and Dispersion accuracy.
Scanspeak D3004/6640-00 Be Dome
Scanspeak R2904/7000-00 Ring Radiator
RAAL 150-4D Amorphous Core Ribbon
My apologies! My brain went into over drive after reading this whole thread and typed the RAAL model incorrectly in my post before.
It should read RAAL 140-15D Amorphous Core Ribbon.
Old 11th August 2011, 10:41 PM   #124
6.283 is offline 6.283  Germany
Megasat, it does not really matter what it reads. These are three different tweeters for two and a half or three different applications. Take the one that fits your application. In case you don't know what your application is, double-check
off axis behavior / directivity match @ x-over point to the next larger driver.
For some of my applications, the BE dome would be worthwhile auditioning. But the price tag is scary.
2Pi-online.de
Old 12th August 2011, 12:41 AM   #125
Originally Posted by 6.283 View Post
Megasat, it does not really matter what it reads. These are three different tweeters for two and a half or three different applications. Take the one that fits your application. In case you don't know what your application is, double-check off axis behavior / directivity match @ x-over point to the next larger driver.
Thanks 6.283! I am now in the information gathering stage. Not really in a specific application designing stage. But when the drivers are picked, it's my best interest to get them worked together in unison.
And you can't always manufacturer plots come with the data sheets.
I think the price of BE dome isn't too bad when compared to other high end commercial speaker offering but only if the BE dome works better and sounds better than $40 tweeter raved by DIYers.
Old 25th April 2016, 01:46 PM   #126
mtoc is offline mtoc
Banned
My friend tells me the answer is true ribbon from Magnepan, even better than SS Be tweeters.
Old 25th April 2016, 04:28 PM   #127
Face is offline Face  United States
Face's Avatar
It all depends on your preferences.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Old 25th April 2016, 05:32 PM   #128
eriksquires is offline eriksquires  United States
eriksquires's Avatar
Unfortunately I have not listened to the 2904/7000 in a very long time.
I really like listening to the low end version (i.e. Vifa XT25BG04 / SS R2604/8330) which is better based on frequency response. The top octave is perfectly flat, and sounds very nice compared to the Mundorf AMT's I use. The dual magnet XT25 has very low distortion around 1-2k compared to the single magnet version, so I'm not recommending the small one. I believe Zaph also felt the XT25 was a better value, though he only tested the small one.
Which brings me to my second suggestion, yes, the Mundorf AMT's. There are significant differences in dispersion characteristics among the three tweeters, which is important. Measurement wise, the Mundorf AMT's are just unimpeachable (a phrase I have a feeling we'll here a lot of in the next four years, boom!). Incredibly low distortion, immeasurable compression (at least with OmniMic) and high power handling and no ringing even in the sealed versions.
Lastly, the low-ball ScanSpeak Beryllium tweeters ($270 - $290) are two I would have to investigate before spending the big bucks on the R2904/7000. In this case the small one looks easier to integrate, and I'm a bit of a Be slut.
Best,
Erik
All of my successes and failures can be explained by my attempts at getting a girlfriend. All of them.
Old 26th April 2016, 01:13 AM   #129
system7 is online now system7  United Kingdom
system7's Avatar
I've tried all sorts of tweeters, except the ring radiators to date.
They are all pretty awful IMO. I've had a bad time with spitty Morel soft-domes and grainy Visaton mylar domes. The last images.
It's a relief to get back to cone tweeters.
HT-22/8
7 a pop, 92mm rebate, and great musicality. I'd consider some ring radiators because they address the hopeless dome breakup at the centre of domes. Ribbons, an all that, yeah, why not. I've heard some good ones.
Best Regards from Steve in Portsmouth, UK.
Old 26th April 2016, 03:00 AM   #130
Steve, "I don't live in the past" strikes again!
Seriously though, I wonder if you aren't also a big fan of that tight dispersion pattern. If so, try an inexpensive ($30ish) ring radiator.
Steve when you say "hopeless dome breakup" is there an easy statistic or graph to say "Aha, there's what Steve was talking about!" ??? I mean, is this something I could see in all those fancy dome spec sheets, or do I need to do targeted testing?
Best,
Erik
What beats the R2904/7000 ring radiator?Hide this!Advertise here!
Repair r2904 ring radiator - how to? BNK Multi-Way 1 27th March 2009 01:15 AM
FS Pair Scan Speak R2904/7000 mp006ltk Swap Meet 3 25th March 2008 04:37 PM
New Scan Speak R2904/7000 Antonio Swap Meet 4 12th January 2007 11:08 PM
SS 18W8531 and R2904/7000 Jota Multi-Way 2 6th December 2006 12:06 PM
SS R2904/7000 ring vs SS D2904/71000 dome opinions?? Adam D Multi-Way 0 1st September 2004 11:39 PM
Copyright ©1999-2017 diyAudio
