I think most people agree that running a pair of woofers in push-pull is an easy way to cut distortion. Drivers with the most difference between their out stroke and in stroke benefit the most. Would there be much benefit to using one column of drivers facing out next to another column facing in for midbass freguencies? Another possible arrangement is one column with the drivers alternating facing out and facing in. These drivers would only be working down to 70 hz but since this does not cost anything extra it might be worth trying. Any ideas or experience?
Thanks, Ted |
#2 |
With magnet facing out there will be unwanted diffraction at higher frequencies
Besides, the greatest advantage of pushpull will be at LOW frequencies, and most significant with some cone movement The line array itself, with many drivers, ought to have greater impact on this issue, non-linear distortion |
| push-pull PWM IC | chimi | Power Supplies | 19 | 4th September 2008 09:32 AM |
| modify parallel push-pull EL84 to single push-pull | chungtat | Tubes / Valves | 12 | 3rd November 2005 11:25 PM |
| Parallel Push Pull Drivers | gingertube | Tubes / Valves | 14 | 13th May 2005 01:32 PM |
| Is the Zen really a push-pull? | Kashmire | Pass Labs | 3 | 17th August 2004 09:07 PM |
| Double push-pull versus single push-pull | jraraujo | Tubes / Valves | 19 | 19th October 2002 12:23 AM |
| Page generated in 0.06189 seconds (72.30% PHP - 27.70% MySQL) with 10 queries |
